0 Members and 1 Guest are viewing this topic. Read 5598 times.
I would think 107 would be just fine. I think 110 is what the line voltage is right?
Thanks guys - hmm, variac sounds good though I like the idea of something that monitors it automatically. Those APC units look like a good reasonably priced option. Thinking APC plus blue circle thingee OR a furman 1215. Thanks all
Hi guys, preparing for my new JWN/Salk/Cary system and I measured my wall voltage at 107-114. On my old system I had a Tripp lite line conditioner which I just measured and it stepped it up to 130-134. I'm assuming 107 may be harmful, is the 130 from my Tripp lite ok or should I replace it? (Spec says it should step it up or Down to 120. It's about 15 years old (lc6 I think).Thoughts?
You've got some real problems and it's not just your audio system. The low voltage is bad news for your refrigerator and air conditioner too. Likely cause is that you are far from the utility transformer and the feeder from the utility is heavily loaded.
Thanks everybody, turns out it was in fact a bad DVM meter - I got a Klein and the votage is between 114 and 119.
