Would a miniDSP unit do the trick for bass management? It'll allow you to cross over to the F12 sub, and you can even apply parametric EQ to the subwoofer. It's cheap too!As for a tube amp, I'll let those that like the results of said design comment on that one.
You maywant to look at Oppo 105. you can run the xlr of the Oppo to your integrate or future tube amp and the sub out to your Rythmik. (select small Front + sub in Oppo speaker s/u page).Yes, the EE dac ”maybe better” but IMO, the Oppo dac is not that bad either. and on the plus side you gain a preamp, a blu ray, sacd player and the most importance is the bass managerment systemat a very afordable price. And yes, you will have tube and you have a full range system
Yes, it is almost a all in one player. While I find it is a very natural preamp, its out put is higher than what I use to see in a normal preamp. This will not be a problem if you are not doing a lot of listening late at night. The 105 has usb, coaxial, optical, hdmi input and wireless streaming. It can play almost all files types.
Amazing piece of gear... so if used as a pre amp, where is the volume control if it's fed to a power amp?
right, using the oppo as a preamp might work but why would you do it? you can easily get several preamps that do bass management. the emotiva preamp and the parasound P7 and a tube amp would do it, and you could stick within your budget depending on what amp you get.
Just for clarification Bigfishhk before I venture an amp recommendation, are you asking about a tube integrated, tube separates (pre/power) or just a tube power amp? Given your budget, the flavor of tube 'amp' you're after makes a significant difference in what might be in play.
The volume is controled from the Oppo remote and uses the digital volume control function of the ESS Sabre 32 DAC chips. http://www.oppo-bluray.co.uk/UserFiles/Docs/PDF/BDP-105EU%20Direct%20Power%20Amplifier%20Connection%20V2.pdf Steve
Thanks for the info re remote volume control. Curious why Austin08 advises:"its out put is higher than what I use to see in a normal preamp. This will not be a problem if you are not doing a lot of listening late at night. "
Gotcha Bigfishhk, since you want tube sweetness plus bass management my view is your best bet is a SS pre/processor and a tube power amp. I'll let the members better versed on the HT side weigh in on the pre/processor but as a hard-code music high ender I know amplification like the back of my hand.
Don't the miniDSPs add noticable delay to the signal (in the range of 10-20 milliseconds)? The units I investigated (going back as far as the SMS-1) did, so I couldn't use them for just bass management. You'd need to run the full signal through the unit and then split after the processing. Since I'm mostly analog, that didn't cut it.
