0 Members and 1 Guest are viewing this topic. Read 11957 times.
As I read it, your earlier thoughts weren't about the Buss vs RSA but were about the Buss with the RSA. You not only didn't do a direct comparison of the Buss vs RSA, you didn't even demo the Buss alone in your system w/o having the RSA attached. That was a real shame IMHO as you really have no idea what the Buss alone might have done for your system.Cheers,Robin
Well their recommendation for the amp is straight into the wall so I'd assume so but don't know for sure.
Before we get carried away with comparisons, it should probably be mentioned once again that the impact of power conditioning has been reported to be very system dependent. Both with regards to the specific equipment being conditioned, and with regard to the quality of power coming into your home & the presence or absence of EMI/RMF factors. Listen for yourself in your system. Audition, audition, audition. Of course this goes for other components too.
+1There is so much to be said about active vs. passive filtering ...All of it is system AND power (to your home) dependent Transformer based conditioners have not stayed in my system ...
In general - Preamps, DACs, Transport (low power consuming electronics) tend to benefit from Active while Power Amps - especially big ones lose dynamics with Xfmer based units ...That being said Uberbuss is not a bad buss to board ... you have money back option too if it does not work for you
I realize the power requirement is not as high as a regular amp but where do the high wattage class D-Amps fit into that equation?JP
