mysterious or defective poti of my ONE.2?
lilakmonoke
« on: 8 Dec 2012, 09:48 am »
hi seth and all ... my ONE.2 has developed a strange problem and before i take it apart i would like to get some hints as to what it is. the stepped poti only works on one channel, the other one is alway full on. if i rap the amp gently it will then work correctly or lower the volume of the full on channel. some connector came loose? thanks for any advice! florian from berlin
lilakmonoke
Re: mysterious or defective poti of my ONE.2?
« Reply #1 on: 8 Dec 2012, 03:47 pm »
nobody has a clue?
medium jim
« Reply #2 on: 8 Dec 2012, 03:53 pm »
Hard to say without seeing it...could be a cold solder joint...
Jim
lilakmonoke
« Reply #3 on: 8 Dec 2012, 04:33 pm »
not a connector? everything is soldered?
Jason T
  • Enjoying the music
    • custom cables
« Reply #4 on: 8 Dec 2012, 05:05 pm »
the stepped pot is bad.
I have a revised version here, if your good with a soldering iron I can send one out, if not you will need to get your amp back to me for repair.
lilakmonoke
« Reply #5 on: 8 Dec 2012, 06:42 pm »
ah ok ... so its not that easy. i sent you mail, jason. thanks!
