Vortexbox users?
0 Members and 1 Guest are viewing this topic. Read 1068 times.
JoshK
Vortexbox users?
« on: 6 Dec 2012, 05:54 pm »
So I have a vortexbox as I pretty much adopted SB's early on.
Truth be told, I haven't been using it as I haven't set it back up since my move.  I was close to reaching the 1TB space limit so I need to upgrade the disc space or at least use an external disc to expand.
I am wondering if anyone has good tips for upgrading, expansion, etc.  Anyone try to put a  SSD drive it one?
Wondering if USB/coax solutions are more betta than SB's.
I was planning to set it back up tonight, so was looking for tips.
Josh
JoshK
Re: Vortexbox users?
« Reply #1 on: 6 Dec 2012, 06:08 pm »
I should add that I am using a Lite Audio DAC-83 which does not have USB.
firedog
« Reply #2 on: 6 Dec 2012, 06:30 pm »
Try Vortexbox.org. A wealth of info there. You can certainly use an SSD for the VB OS and a large conventional drive for the storage/media drive. Look for something called a "2 disk install" for Vortexbox.
http://info.vortexbox.org/tiki-index.php?page=ISO+Install
http://info.vortexbox.org/tiki-index.php?page=twodiskinstall
