Nitro IC's with Silver NextGen connectors?
0 Members and 1 Guest are viewing this topic. Read 5073 times.
Marbles
« Reply #20 on: 10 Jul 2004, 09:07 pm »
Quote from: TheChairGuy
I have $300 ZSLeeves on my digi cable AND the IC from my DAC to pre...do you think I ma benefit from a bybee on the pre - amp IC's that much?
Can't say I've bought into the Bybee 'magic', but I'm flexible and not one to scoff much.
The Bybees seem to be very situation dependant, that is in some cases they seem to improve the sound and in some cases they detract from the sound.
If it were me, I would NOT get the bybees installed and play with the 2 Z Sleeves to see where you get the best bang.  If you still think that there is grunge or edge to the sound of your system, then you can buy a set of IC's with bybees installed.
Wayne1
« Reply #21 on: 11 Jul 2004, 12:37 am »
I would be happy to reterminate anyone's cables with the WBT. Either copper or silver.
ChairGuy you got PM.
If anyone else is interested, contact me for pricing. It will be very reasonable for now :lol:
As to if Bybees will help, the only way to know is to try them. ChairGuy, get in touch with me and I should be able to send you a pair of demo in-line purifiers I have on hand. You can see if they do anything for you. If you like what they do, I could build some into a cable for you.
bubba966
« Reply #22 on: 11 Jul 2004, 12:53 am »
Quote from: Wayne1
So, when do you think I'll be sending you Valhalla's for a silver NextGen makeover? :lol:
Guesses welcome as I'm sure it'll happen someday... :roll:
zybar
« Reply #23 on: 11 Jul 2004, 01:03 am »
Why not just sell the Valhalla's?
I have found equal or better ic's for much, much less.   :lol:
George
bubba966
« Reply #24 on: 11 Jul 2004, 01:08 am »
They're not my Valhalla's.
But at some point my boss will most likely want me to send 'em to Wayne for a NextGen upgrade...
Marbles
« Reply #25 on: 11 Jul 2004, 01:36 am »
I really don't think he will be disapointed.
TheChairGuy
« Reply #26 on: 11 Jul 2004, 02:00 am »
Wayne, thanks...you got PM back at ya' :!:  :!:  :!:
