Fidelia will not work right when using Exclusive access?
0 Members and 1 Guest are viewing this topic. Read 773 times.
Lizard_King
  • Tubes Rule!
I use both Fidelia and Audirvana plus. I used to be abel to use fidelia and have it use exclusive access. Now, when I try to use that, the volume for the mac internal is greyed out so I cannot raise the volume.
Audirvna plus does not have this problem. Any suggestions?
dB Cooper
Re: Fidelia will not work right when using Exclusive access?
« Reply #1 on: 5 Dec 2012, 02:34 am »
Their support is usually prompt; I have had a few issues with the software and they usually respond quickly. Have you contacted them?
