Cable Tryouts I need test subjects
Jason T
  • Enjoying the music
    • custom cables
« on: 29 Nov 2012, 07:20 pm »
guys I've been playing around with our digital coax cables using them as an analog cable.
I've tested them on multiple systems using different amps, speakers and compared to other cables with multiple friend audiophiles present.
Here's what we've come up with.
Surprisingly neutral and detailed.
lower midrange and midbass a touch more laid back than the Nirvana cable but with better top end brilliance.
we found that these cables work wonderfully in systems that need a touch more detail up top with a little less midbass.
most of the time Room affects are what cause the issues and this might be a great resolution for some of you.
I'm hoping I didn't waste all those hours  :duh:
ok so here's the deal, those of you who feel you might benefit from these cables can have a pair for testing in your system.
if you like them send me $75
I only have 4 pairs available for testing so make your move quickly.
if you need a second pair for testing I'll work that out with you.
every cable is assembled with 5% silver solder to match the 5% silver plated wire and of coarse our T copper rca plugs.
because these are 2 conductor I cant do XLR cables.
no orange heatshrink anymore, sorry for the teaser :)
raw
roscoeiii
Re: Cable Tryouts I need test subjects
« Reply #1 on: 29 Nov 2012, 07:35 pm »
What length are these?
Jason T
    • custom cables
« Reply #2 on: 29 Nov 2012, 08:04 pm »
these are 1M cables
starkiller
« Reply #3 on: 23 Mar 2013, 04:06 am »
Dang!  NOW i see this :duh: :duh:
Jason T
    • custom cables
« Reply #4 on: 23 Mar 2013, 04:51 am »
I think I just might have a pair left :)
email me cables at virtueaudio . Com
