0 Members and 1 Guest are viewing this topic. Read 3408 times.
I am struggling to wrap my head around the need for a FIR or IIR filter inside a DAC. I understand that there are artifacts, as low as 24.1 kHz when sampling at 44.1 kHz, from the 20 kHz image but it's inaudible to us humans. Discussion then starts up regarding the pros and cons of different filter methodologies like phase-linear, minimum phase, roll-off, ringing, etc. Why not just skip the filter?
As for the Oohashi tests that claimed to prove we can hear ultrasonic content, that was debunked a few years later by another group of researchers who traced the problem to those same sum and difference frequencies caused by IM distortion in the tweeter. The text below is from my Audio Expert book.--EthanThere was also a study by Tsutomu Oohashi that’s often cited by audiophiles as proof that we can hear or otherwise perceive ultrasonic content. The problem with this study is they used one loudspeaker to play many high-frequency components at once, so IM distortion in the tweeters created difference frequencies within the audible range. When the Oohashi experiment was repeated by Shogo Kiryu and Kaoru Ashihara using six separate speakers, none of the test subjects were able to distinguish the ultrasonic content. This is from their summary:"When the stimulus was divided into six bands of frequencies and presented through six loudspeakers in order to reduce intermodulation distortions, no subject could detect any ultrasounds. It was concluded that addition of ultrasounds might affect sound impression by means of some nonlinear interaction that might occur in the loudspeakers."
"It was concluded that addition of ultrasounds might affect sound impression by means of some nonlinear interaction that might occur in the loudspeakers."
"Might" is speculation. There is no solid conclusion to their "experiment" which will be contradicted below.
One loudspeaker was not used for all frequencies including ultra-high, but a separate ultrahigh dome diamond tweeter. Extremely high slope filters were used to prevent ultra highs and lows from mixing.
Dr. Kunchur's work has been presented to a variety of specialities, Scientists, Electronics, University, and National medical organizations etc, besides being peer reviewed.
author=Ethan Winer link=topic=111949.msg1160773#msg1160773 date=1354295849]I think this is perfectly clear:"When the stimulus was divided into six bands of frequencies and presented through six loudspeakers in order to reduce intermodulation distortions, no subject could detect any ultrasounds."
Sure, but the problem is IM difference frequencies between the ultrasonic frequencies. If you mix 60 KHz and 65 KHz nonlinearly, you get a 5 KHz difference tone which is audible. So segregating the in-band content from the ultrasonic content is not enough to avoid those artifacts.
That's a very different issue, but Kunchur's work has been called into question (to put it kindly) by people a lot more knowledgeable than me:http://www.hydrogenaudio.org/forums/index.php?showtopic=73598
For those who have no idea what science and the (incredibly rigorous) scientific process is, let me explain what went into publishing the two above mentioned papers that have apparently generated controversy among lay readers (but no controversy whatsoever in all the professional circles, which include audiolists, otolaryngologists, acousticians, engineers, and physicists ).
Whether people can hear, or otherwise perceive, ultrasonic content has been researched many times over the years, and I'm not aware of any credible evidence showing that it's audible.
I see no measurements, just speculation.
In my previous post, I had no reservations posting/listing the massive medical backup, from at least three national medical organizations, plus electronics, electrical engineering, universities, physics etc, who actually do the research. In otherwards, mainstream science.
So it is not surprising that they would attack with a vengeance Dr. Kunchur, Oohashi, Nishini etc.
multiple national mainstream medical organizations dealing with hearing, multiple main stream academia, engineers, physicists, peer reviewers, main stream science
at least two members who have posted in that string have been witnessed on other forums (Stereophile, AVS etc) altering Dr. Kunchur's work/conclusion and Oohashi, Nishini etc PET/EEG measurements, and claiming the tests were flawed. Both eventually admitted they presented false information. That raises the question of ethics.
Dr. Kunchur's paper demonstrated, and concluded that a 5us timing change for each ear, independent of the other ear, was perceived; which does require ultra sonic information to be available.
What part of "nobody could hear it" is unclear? The article is AES Convention Paper 5401 Presented at the 110th Convention 2001 May 12–15 Amsterdam. This is a for-pay article so I can't just post it for the public. If you don't have this paper, email me through my web site www.ethanwiner.com and I'll send you the PDF. In the mean time, this part describes the test subjects:
"Ten males and 3 females participated as the subjects. All of them were either undergraduate or graduate students and had normal hearing. Their ages ranged between 19 and 26 years. They were paid for their participation. None of them could detect any stimulus above 22 kHz when it was presented as a single tone with the level below 85 dB SPL."
Unless I missed something, you didn't post any actual evidence or study excerpts. You just made a claim and left it at that. Were the tests you cite flawed in the same way as Oohashi, where in-band IM products were present?
We thank the staff of the Kyoto University PET Center for valuable contributions to this work; Dr. Yoshio Yamasaki, Waseda University, for the use of his recently developed signal processing system; the Yamashiro Institute of Science and Culture for recording the sound sources; Dr. Norihiro Sadato, National Institute for Physiological Sciences, for valuable comments on an early version of the manuscript; and Dr. Masako Morimoto, Japan Society for the Promotion of Science, for valuable technical support. This work was supported in part by the Japan Ministry of Education, Science and Culture, through the Grants-in-Aid for Scientific Research (A) (09490031) to T. Oohashi, on Priority Areas to H. Shibasaki, and for International Scientific Research Program (10041144) to T. Oohashi, and by the Japan Society for the Promotion of Science through the Research for the Future Program JSPS-RFTF 97L00201 to H. Shibasaki.
The problem with Oohashi's test is self-evident, as already explained. But I should have been clearer in my post yesterday. If you read through that Hydrogen Audio thread I linked, you'll see that Kunchur's main mistake was not realizing that bit-depth affects the time resolution of digital audio. So if I understand it correctly, Kunchur was off by a factor of 16 since each of the 16 bits in a CD quality Wave file doubles the available time resolution.
That's just Argument From Authority, without actually making a case.
And that's just an Ad Hominem attack. I was there and witnessed those discussions, and they were nothing like what you describe. Do you have a link to HA forum participants admitting they presented false information?
I'm sorry Steve, but this is simply incorrect. As JJ explained clearly, regular CDs have that much timing resolution too. Again, what you and Kunchur miss is that the number of bits used increases the resolution.
First of all, an internet forum is a dangerous place to obtain information -- instead one should go to an authentic original source such as a published scientific paper in a refereed journal. In such a forum, a writer can post completely arbitrary, unproven, and indeed totally wrong statements with no backing or oversight whatsoever. Normally this would be a laughing matter, except that sometimes people obtain their "education" through such forums and this can therefore cause longterm and serious damage...For those who have no idea what science and the (incredibly rigorous) scientific process is, let me explain what went into publishing the two above mentioned papers that have apparently generated controversy among lay readers (but no controversy whatsoever in all the professional circles, which include audiolists, otolaryngologists, acousticians, engineers, and physicists )...
What I don't understand is why some audiophiles feel the need to prove we can hear ultrasonic content. It's like a holy grail for some people, even though it defies 100 years of audio knowledge. Even if it were true that in some rare situations people can perceive ultrasonic content, so what? Why does this matter?
Your chart has nothing to do with timing resolution.
Steve wrote:However, let us check out Ethan's quote of JJ "regular CDs have that much timing resolution too" in the graph below. One can see the inaccuracy of a 3us pulse at 48k (not 44.1k), and 5us is not much better. Notice the slope (rise time), ringing, distortion with 48k. (Imagine using it for scientific testing.) I see no inaccuracy, ringing or distortion! Also the slope (rise time) is appropriate. All of these traces are what you get when you try to run an ultrasonic signal through a low-pass filter. Your chart has nothing to do with timing resolution.
