Build LS-9
0 Members and 1 Guest are viewing this topic. Read 23381 times.
tubesaab
Build LS-9
« on: 21 Nov 2012, 07:13 pm »
Hello
I am going to build LS-9,,,,like to make the side thicker..the drawing said 3/4 inch----how big is the problem on sound ,if i make the front plate 1inch  more wide (13.375inch instead off 12.375 inch)  :roll:
i will not change sound in any way........
Best Bjarne
Cheeseboy
Re: Build LS-9
« Reply #1 on: 21 Nov 2012, 07:29 pm »
I think you will make a significant change the sound by building front baffle wider than called for in the plans.
tubesaab
Re: Build LS-9
« Reply #2 on: 21 Nov 2012, 07:33 pm »
if it change the sound i will not change the mess
Danny Richie
Re: Build LS-9
« Reply #3 on: 21 Nov 2012, 07:57 pm »
Total front baffle width needs to be maintained.
Put a really large radius on the edges or cut the front edges back at a diagonal and you can use thicker side panels.
I had one guy curve the sides by milling a 1.25" thick side panel down to 3/4" at the front and back ends. It was a lot of work, but looked really good. And it was really solid.
tubesaab
Re: Build LS-9
« Reply #4 on: 21 Nov 2012, 08:33 pm »
thanks
I will keep the mess on the front
what about make the side thicker inside the enclosure,,,and make it a bit deeper  so i keep the volume?
Danny Richie
Re: Build LS-9
« Reply #5 on: 21 Nov 2012, 08:37 pm »
thanks
The inside edge of the woofer is already right at the inside edge of the inside of the enclosure. So to make it thicker it will need to be thicker on the outside.
tubesaab
Re: Build LS-9
« Reply #6 on: 21 Nov 2012, 08:41 pm »
ok i will keep the mess
next step saw the plates,,hope to do that soon
tubesaab
Re: Build LS-9
« Reply #7 on: 25 Nov 2012, 11:45 am »
Where is the best place to hide the crossover,,,,,in the box or at the back of the box
best Bjarne
Danny Richie
Re: Build LS-9
« Reply #8 on: 25 Nov 2012, 06:42 pm »
best Bjarne
The crossovers easily fit in the bottom of the box.
tubesaab
Re: Build LS-9
« Reply #9 on: 25 Nov 2012, 07:38 pm »
Super then i can go on with the wood..
tubesaab
Re: Build LS-9
« Reply #10 on: 28 Nov 2012, 09:35 am »
How much polyfill (weight) for each driver ?
The polifill i can buy here, is different weight---some 100g,,and some 300g  m2
http://www.netsound.dk/da/daempemateriale/91-daempemateriale-hojttaler.html
tubesaab
Re: Build LS-9
« Reply #11 on: 8 Dec 2012, 01:46 pm »
 The new enclosure goes the right way...side and top and buttom i ready to fish together
next week i vill make front ready...vi must make a program to the cnc to make all the holes-
some pretty big sides i must say :thumb: :lol:
stevenkelby
  • Adelaide, South Australia
Re: Build LS-9
« Reply #12 on: 8 Dec 2012, 02:01 pm »
I'm excited for you, you must be looking forward to hearing them a lot!
Any pics of the work in progress?
tubesaab
Re: Build LS-9
« Reply #13 on: 8 Dec 2012, 02:14 pm »
yes it is hard to wait
i will se if i can take some foto--must find out how i can paste them ind the forum
stevenkelby
Re: Build LS-9
« Reply #14 on: 8 Dec 2012, 02:20 pm »
PM me if you need help posting pics and we'll work it out.
It's very easy, when typing a reply, hit the "preview button" under the text box, then on the page that opens, click the button under the text that says "Upload and insert an image". Click on "Browse" and find the photo on your computer. Click "Open" and wait for it to load. Done!
tubesaab
Re: Build LS-9
« Reply #15 on: 8 Dec 2012, 02:24 pm »
how big must the picture be  (kilobyte) or what
stevenkelby
Re: Build LS-9
« Reply #16 on: 8 Dec 2012, 02:29 pm »
It doesn't seem to matter, I use pics about 4MB and they upload fine. The forum resizes them itself. This was 4MB:
tubesaab
Re: Build LS-9
« Reply #17 on: 8 Dec 2012, 02:35 pm »
that is great...must maybe wait to tomorrow ,here is it near dark ,,will try later with blits on the  camera
what a fine dog,,and taken in sommertime..hear in denmark it is bitter cold
stevenkelby
Re: Build LS-9
« Reply #18 on: 8 Dec 2012, 02:42 pm »
Thanks, she is a great one and yes it is hot here :)
Looking forward to your pics!
Steve.
tubesaab
Re: Build LS-9
« Reply #19 on: 8 Dec 2012, 02:58 pm »
will try a picture off the sides and top
standing next to my speaker,,,those are not small
[/img]
