Dynavector noise
0 Members and 1 Guest are viewing this topic. Read 2331 times.
Delacroix
Dynavector noise
« on: 18 Nov 2012, 06:49 pm »
As an interim solution to a cartridge problem (detailed in other post), I got a good deal on a new Dynavector 10x5 to keep me spinning. Got it all set up this weekend but I am having a peculiar problem with loading that is befuddling even my dealer. Running it into a Whest 0.03RDT phono stage at the recommended 47k loading, I get all sorts of weird, high-frequency noise that comes in and out intermittently. If I move my tonearm cable, this can help a little or make it worse, a bit like moving a radio antenna around but it's unpredictable, even when it starts out quiet, this high pitched sound can arise during playback.  Problem only disappears fully when I load cartridge down at 1k. Trouble is, it sounds better at 47k or even 15k, the 1k is a bit soft sounding for my ears but at least it's quiet. Strange phenomenon, anyone here have a clue what's happening? Never experienced this with any other cartridge in this or similar set-ups.
Wasatch
Re: Dynavector noise
« Reply #1 on: 18 Nov 2012, 08:55 pm »
I doubt very much it is the cart. I had a DV 10x5 with a DV P75 MkII and never had any problems with that combo. Switch out the Phonostage.
Wayner
« Reply #2 on: 18 Nov 2012, 09:45 pm »
Sounds to me like your interconnects have become an antenna with this particular combination. Look for a better pair of interconnects that are better shielded.
Wayner
Delacroix
« Reply #3 on: 20 Nov 2012, 11:19 pm »
Problem solved -- it was a gain mismatch with the high output 10x5  -- had the internal dip switch on too high a setting.  :duh:  One more reason why I dislike internal jumpers and dip switches.
S Clark
« Reply #4 on: 21 Nov 2012, 12:54 am »
You said you found a good deal on one.  Just so happens, I'm looking to buy a 10x5.  Would you mind sharing your source?
Scott
vortrex
« Reply #5 on: 21 Nov 2012, 01:04 am »
Scott
I think user 2juki on ebay probably has the best prices.
Delacroix
« Reply #6 on: 21 Nov 2012, 03:20 am »
Scott
PM sent -- it's a real dealer.
