software volume control
0 Members and 1 Guest are viewing this topic. Read 1262 times.
avta
« on: 17 Nov 2012, 03:37 pm »
I would appreciate some input about software volume control. A number of dacs do not have built in volume control. If one does not have or does not want to use a preamp can software volume control work without compromising soung quality?  I'm thinking about programs such as iTunes or possibly Audirvana Plus ( I don't have this so I'm speculating ). Any thoughts?
toddbagwell
Re: software volume control
« Reply #1 on: 20 Nov 2012, 06:58 pm »
you can control the volume digitally.
by doing so, you will lose some resolution.
depending on the software/coding of the player, it may be noticeable to you or it may not. some programs simply cut off bits. other programs have up-sampling and dithering algorithms that allow for much more attenuation before significant quality reduction.
the generic answer is to try for yourself and decide if you can tell a difference.
« Reply #2 on: 20 Nov 2012, 07:04 pm »
This is a old prob not fixed yet, in the 90 years Wadia stated his machines lose 1 or 2 bits in resolution with dvc.
toddbagwell
« Reply #3 on: 20 Nov 2012, 07:06 pm »
from one of my favorite sites for good explanations of things digital audio:
http://www.thewelltemperedcomputer.com/Intro/SQ/VolumeControl.htm
Noseyears
  • SS-Audio
    • Supreme Sound Audio
« Reply #4 on: 20 Nov 2012, 07:41 pm »
From my understanding, software digital volume control works just as well as a hardware controls. As long as it uses the maximum (usually 24 bit) resolution your Dac is capable of.
srb
« Reply #5 on: 20 Nov 2012, 07:55 pm »
From my understanding, software digital volume control works just as well as a hardware controls. As long as it uses the maximum (usually 24 bit) resolution your DAC is capable of.
Yes, for 16 bit files, which would give you 8 bits or 48dB of possible attenuation.  If you're playing high-res 24-bit files you will be chopping off bits with any amount of attenuation using a 24-bit volume control and 24-bit DAC.  If you have a software player with 32-bit volume control and a 32-bit DAC you will have the 8-bit/48dB volume attention for 24-bit files with no loss.
That being said, even when I play 16-bit files into my 24-bit DAC, I still hear reduced dynamics playing at low volumes when using using the iTunes 24-bit software volume control, even though technically I shouldn't.
