Cory Super Hi Gloss Piano Finish
0 Members and 1 Guest are viewing this topic. Read 8283 times.
harley52
Re: Cory Super Hi Gloss Piano Finish
« Reply #20 on: 1 Jan 2013, 02:38 am »
You may want to check to see if the polish is a petroleum based product. If it is DON'T use it. Petroleum based wax, polish or whatever will dry the finish out. Same thing with wax/polish for your car. Use a bees wax based product, such as Zymol and not the stuff you find in Walmart. Check on line or a speed shop,hot rod parts store.
es347
  • ..I've got my eye on you...which one you say?
« Reply #21 on: 1 Jan 2013, 03:18 am »
Hey there Harley..
I couldn't say one way or the other as the label doesn't list ingredients.  I can say however that having used this product on my gloss black finished speaker cabinets, both the rt/left mains and subwoofers, that the finishes look better than ever.  I use it about once per month and it not only shines but tends to eliminate static as well.  Highly recommended.
Guy 13
« Reply #22 on: 1 Jan 2013, 03:20 am »
Hey there Harley..
Hi es347 and all Audio Circle members.
I know, completely off topic, but I will ask anyway.
What is the name of that actor on your avatar?
Guy 13
es347
« Reply #23 on: 1 Jan 2013, 03:23 am »
That would be one Marty Feldman..  :thumb:
Guy 13
« Reply #24 on: 1 Jan 2013, 03:26 am »
Thanks and Happy New Year.
Guy 13
