Ncore on/off switch
0 Members and 1 Guest are viewing this topic. Read 2248 times.
drmike
Ncore on/off switch
« on: 14 Nov 2012, 01:26 pm »
I am almost ready to fire this up. Is an on/off switch necessary? If so what would be a good one for the front of the silicon ray case? Do you leave these plugged in when not in use?
drmike
jtwrace
    • TIPP YouTube Channel
Re: Ncore on/off switch
« Reply #1 on: 14 Nov 2012, 01:31 pm »
drmike
You can either have no on/off switch and have an nAmpon or both.  I choose IEC/switch wtihout an nAmpon.
Yes, plugged in all the time.  Why not?
http://www.newark.com/jsp/search/productdetail.jsp?SKU=60R5556&source=CJ&CMP=AFF-CJ-5567334-Newark_element14
jmbulg
« Reply #2 on: 14 Nov 2012, 01:33 pm »
Mine have only a power on/off on the IEC power inlet at the rear. Otherwise I leave them on all the time and I'm quite happy with this. The only moment when I regret not having a on/off switch exploiting nampon is when I need to make the DC calibration for which I then need to disconnect nampon by hand.
