0 Members and 1 Guest are viewing this topic. Read 111392 times.
Danny, I understand the difference between listening and measuring, but we are not talking about (for example) a piece of wire here, but a circuit that (it is claimed, and amongst other things) changes the effective system Q by a factor of 10. Surely it can't be that hard to show.
I expect we'll have to wait a few years though, as you'll need to get your PhD before Brian will be able to talk to you.
It's not like they're in an industry that provides real/valid explanations for audible claims. The whole industry is full of it (little pun there.)I'm actually fine with Danny's exclamation that you just need to hear/experience the result and not worry about the technical details. If potential customers are convinced and lay down their money, excellent.I think it might be easier and more successful if Brian would actually take down a bunch of the technical information on his website. Most of the customers wouldn't really care one way or the other, and it would preclude him getting bogged down in discussions like these.Anyone, besides me, in this thread ACTUALLY have dipole basses in use with their Maggies?
What model is your mic specifically?
The thing that gets me is comments like "every other sub isn't even in the same league" implying, actually straight up saying, that if you don't have a servo sub, you're not going to get the best bass possible. But once you start looking outside this little realm you see that just isn't the case.
Don't be a dimwit. This is a public discussion forum, there is no "qualification" required for entry or participation. The question is really very simple: can you provide measurements to demonstrate the claims being made for your servo system? Seriously, it's a simple question, that never needed to go where you've taken it.
A nonservo sub cannot even maintain steady ouptut when the input is steady.
Judging by the name of the image, this is because of "thermal compression." The time scale is 6.5 seconds, I'd guess I'd question the relevance on that basis, but regardless, how does the servo sub do?Edit: never mind, looks like you edited your post, as your are prone to doing. What's the scale on the FFT (it's hard to read)?
What's the power level?
And which driver is it?
John/AJ,I have a sense you guys are not really EE trained.
great post...Dave
I find it quite amusing.
I would prefer the "here is our technology, I think it is superior, here is our data, yes that other product is nice and well designed, but look at what ours does and why I think our design is better", rather than "... that product is not even in the same league, that product is terrible, just terrible, you'll be suffering if you go that route."
AJ,What was not done was a threshold of audibility level study of each parameter. To me the differences in the Mylar caps in the original Maggie IIB crossover and the replacement Polyproplyene caps was significant sound quality change for the better with the new PP caps. That also correlated with the findings of the article.
I have an old Genesis 12M servo woofer with the metal cone 12". This has a sense coil for motional feedback control. The amplifier is very sensitive to changes. They actually made different gain settings internal to the amp depending on the sensitivity range of the driver in use. There was no way for the user to disconnect the servo loop and keep the driver connected, as that would probably have smoked the amp. My listening findings, seem to be like yours about servo woofer systems and goes back to 1979. The first Infinity IRS Reference III's had accelerometer based motional feedback servo control. This was a six-12" driver per side setup with 1.5KW of amp power per side. This was truly an ear opening experience. From my listening to the OB servo subs in the Super-V's, this is in the same league. What is needed in this discussion is a test methodology like is being proposed to try and measure the differences between a servo and non-servo driver. Since the servo amp was never intended to to be used open loop that does not makes sense. The same amp without the servo feedback system does make sense. That is what I belive is now being attempted.Possibly one way to analyze the difference is to use a subtractive method to see what the difference function is between the two measurements. There will be linear and non-linear components that will need to be analyzed. Just a thought.
