iPad On-or-Off while BDP-1 is playing iPad created playlist?
0 Members and 1 Guest are viewing this topic. Read 970 times.
fado
Does the iPad have to be on all the time the playlist is playing or can I turn it off after the
BDP-1 starts playing it?  I have not figured out how to make a playlist yet otherwise I would
just try it.
I think I should wait until the new software is released until I start learning - are you still looking
at mid-November for the new software release?
Thank You
  • The Demo is Everything!
    • http://www.bryston.com
just try it.
Thank You
Once the playlist starts you can turn the iPad  off.
james
