Tweaking a Grado RA-1 headphone amp
0 Members and 1 Guest are viewing this topic. Read 3665 times.
Dredster
« on: 15 Jun 2004, 02:08 am »
Looking for some mods that can be done on a Grado headphone amp. I plan on bypassing the cheap volume control and coupling it to my Bent Audio Transformer volume control. Any other internal mods which would improve on the design.
GrahamnDodder
    • http://www.xmradio.com
« Reply #1 on: 15 Jun 2004, 02:37 am »
The Grado amp might not be worth doing a mod like that. If it were me, I would buy a used META 42 or buy or build a PPA from head-fi.org after selling the RA-1.
Tons of info here, and at head-fi.
GnD
rickcr42
« Reply #2 on: 6 Jul 2004, 04:34 pm »
being a very basic gain stage the RA-1 is actually easy to upgrade but you will be changing the character of the sound by doing so.
Possibilities would be adding a dedicated regulated power supply ,class A biasing of the output , changing the volume control to a higher qality unit and maybe replacing the input caps.
The strength of the grado , some say weakness,is the opamp used which specs out at 70 ma current drive to the headphones and since Grado cans like current it is a good match.Plus the slightly soft voicing of the passive parts/opamp is geared specifically towards taming the grado rising top end
hope this helps
NotoriousBIG_PJ
« Reply #3 on: 27 Aug 2004, 06:44 pm »
I found the meta to be a poor match with grados. Stick with the ra-1.
Biggie.
