Hello, all-- I have had a super busy couple months, but managed to squeeze in enough Sundays to finally complete my Cornet 2 build. What a fantastic kit! Unfortunately, I did not have that magic "worked the first time" experience. I have serious right channel issues with my Cornet2. At first, I thought I had NO right channel output at all. Then I listened to it with a headphone amp connected to the Cornet 2 output and heard a very quiet, distorted signal passing thru the right channel. The left channel functions PERFECTLY. I should point out that I have the Cornet2 PCB connected to the top plate of my Lansing Enclosure, and also have the chassis side panels installed, but am testing it with the rear panel wiring and the rear panel itself entirely connected ELECTRICALLY... but the rear panel is not physically attached to the rest of the Cornet2. It is grounded to the PCB properly. I built my Cornet2 with the "stock" PCB-mounted RCA jacks, to be changed later to an upgraded RCA jack so I believe it is not RCA jack wiring issues. SO-- here is the issue; great sound from the LEFT channel of the Cornet2 connected to my turntable (Quality VPI table; in perfect order; works perfectly with my Audio Research preamp; so this is not a turntable/cartridge/interconnect issue here) but still has less than 1/20th the output in the right channel of the Cornet2 and even that is with much distortion. I immediately started troubleshooting. I grounded the negative of my voltmeter to the rear panel (the rear panel is connected to "earth" tab on PCB) I then touched the other probe to the 155 volt test point, which is resistor 219R; To my amazement, the missing right channel immediately came in loud and strong, balanced with the left channel, and producing clean, beautiful sound! I removed the meter probe from resistor 219R and the right channel disappeared again. Then I made contact with the positive meter probe to the screw that attaches Q200R to its heatsink; SAME THING! The right channel comes back in, in full splendor. Grounding issue? Before I forget, my voltages with a 5V4GA are running about 30 VDC HIGHER in the malfuntioning right channel than the left channel. Those left channel voltages are within 7-8 VDC of spec. At the right channel 155 VDC test point I have almost 190 VDC. At the screws bonding Q200R to the heatsink I also have 30 volts higher in the right channel. MY LED D100 is not functioning at all; I STUPIDLY mounted it to the wrong side of the board after a long build session and had to desolder it, pull it thru the PCB, and reconnect; I either toasted the LED or damaged a trace on the PCB because it appears to be connected but has no functionality. But at every spec point, like the 330 VDC test point, I have 30 volts higher in the right channel than the left. The other anomaly I noticed is that on Q100R I have one leg that has no voltage present while the other legs have 8 volts DC, same as all three legs of Q100L in the left. I din't measure for AC on the Q100L. Sooo... obviously a grounding issue? What is the likely culprit starving the DC from the right channel? I am just beginning my troubleshoot, having only completed the Cornet2 earlier today... but if these symptoms I am having add up to something familiar to another Cornet2 builder... I'd be much obliged to have someone point out my stupidity, (heh.) I have to say that with both channels operating, even though I didn't want to run it for long in an obvious "problem" state, the sound was fantastic!! WOW! this little "taste" makes me want SO badly to get it righted to start REALLY enjoying the Cornet2! ANY HELP APPRECIATED!!! THANKS! L.P. I will post some pics tomorrow.
