0 Members and 1 Guest are viewing this topic. Read 8533 times.
Err... just so we're clear on the definition, what you are describing is not a monopole. (?)http://www.linkwitzlab.com/rooms.htm#B
In that graphic, it clearly shows 50Hz as being omnidirectional, 500Hz as a narrowing of the pattern to much less rearward raditation and finally 5KHz as very directional. Just as I stated... Not sure where we are disconnecting here. This is standard behavior of a monopole source, such as a traditional boxed loudspeaker. I believe that above, you stated these effects backwards, such that the lows are more directional than the highs.Please note that Sigfried's top diagram is for an "ideal" monopole which is infinitely small AND radiates as a sphere. This is certainly not the case for a traditional boxed(monopole) loudspeaker, as shown in his diagram directly below the ideal monopole.
I don't have a DEQX but I've watched two people use and demonstrate them... and all of the processing done by the DEQX is done by taking measurements, isn't it?Well, as just pointed out, you have one, more or less. So why did you do that?
Hi Greg, I've highlighted the disconnect in bold. I wouldn't consider a traditional boxed speaker to be a monopole - except at low frequencies where it behaves like one. I didn't state it backwards, that's exactly what I said before: "Conventional boxed speakers (drivers on the front) are not monopoles, except at low frequencies." Over the full range, it isn't designed to behave like a monopole, so why insist on referring to it as a "monopole speaker" ...?
