0 Members and 4 Guests are viewing this topic. Read 168173 times.
This is what I am listening to and love it:Polk Audio PSW10 10inch subSMSL Class D AMP 50wX2
How are you successfully able to connect the sub?According to your link, the SMSL amp is a BTL configuration without common speaker ground, and most subs like the Polk have a common ground on their speaker level inputs. (?)Steve
JBL LSR 305 - $300 including Isoacoustics stands from various online retailers. The finest measuring loudspeaker I have seen under $1K or even higher. And I own a pair. 28 inch Pangea Stand - $225/pair - optional as if you have a bookshelf, that might be good enough. Auralic Aries Mini with integral digital volume control -$450-$499. Load it up with your SSD or connect it up to your NAS, enjoy TIDAL all the way up to DSD 256. Optional: add a tricked out 15V DC supply that is either DIY ($150 or less) or from SBooster, etc...Whatever cable manufacturers you subscribe to, or do something inexpensive like DH Labs, Blue Jeans, Signal cable, Pangea, etc...Add a dedicated preamp if your heart desires - tube, solid state, diy, etc...Then stand back and wonder why you are spending so much on your main/regular 2ch system. Best,Anand.
Guy, you obviously haven't priced out a wedding recently....
I hate to recommend it since it's just available from one of our main competitors, but I would suggest the following from Music Direct :Marantz PM6005 : $500Wharfedale 10.1 Diamond : $300
JBL LSR 305 - $300 including Isoacoustics stands from various online retailers. The finest measuring loudspeaker I have seen under $1K or even higher. And I own a pair. 28 inch Pangea Stand - $225/pair - optional as if you have a bookshelf, that might be good enough. Auralic Aries Mini with integral digital volume control -$450-$499. Load it up with your SSD or connect it up to your NAS, enjoy TIDAL all the way up to DSD 256. Optional: add a tricked out 15V DC supply that is either DIY ($150 or less) or from SBooster, etc...Whatever cable manufacturers you subscribe to, or do something inexpensive like DH Labs, Blue Jeans, Signal cable, Pangea, etc...Add a dedicated preamp if your heart desires but not required, i.e. optional - tube, solid state, diy, etc...Then stand back and wonder why you are spending so much on your main/regular 2ch system. Best,Anand.
1. Subwoofer ($400-$1000). This would provide the biggest increase in SPL and make the system more suitable for non near-field use. If it were my money I would choose a sub that has a built-in high pass crossover to allow for greater SPL from the JBL's. I like the GR Research F12 ($1,000) but there are other choices.
