0 Members and 1 Guest are viewing this topic. Read 8608 times.
Congrats to you guf on attaining audio nirvana. Ignore Big Red's recommendation to measure your room; it's a whole other can of words, and sometimes ignorance is bliss.
quite earth (is that the Genesis song reference?)try the phone app db Meter Pro it captures, average, peak and max peak and holds the max very dynamic
He did say he wasn't sure what to take on next. Why not a little paranoia to drive you crazy? Give me ambiguity or give me something else!!
Personally, I listen to the level that I think would be relatively the same as if I were listening to it live. Just my 2 cents.Bryan
Some speakers like to be played louder certainly that others. Personally, I listen to the level that I think would be relatively the same as if I were listening to it live. If I have to listen to Greg Brown,etc. at 90db to get it to sound good, I have a problem...... Not referring to Jim's speakers specifically. I have found them to sound good at a variety of levels.Just my 2 cents.Bryan
When you guys are checking for levels do you use A weighting or C weighting on your Iphone apps? Slow or fast response? To this point I had been using an app called SPL meter on my Iphone, but it doesn't capture peaks and average to my knowledge. Might have to spring for one of these "pricey $.99" apps to see what's going on
Hi Jim, doesn't playing at home give you the chance to 'move a few rows forward'? Like you say, those are the choice seats!Or you could set the hifi so you are the guest of honour, standing by the conductor's side, from time to time being handed the baton!
