0 Members and 1 Guest are viewing this topic. Read 12348 times.
Hm, well, if located out in the room, a larger speaker would have half-space radiation down to a lower frequency, which would be an advantage in terms of reducing reflections from the front wall. Am I warm? That is of course for a box speaker.
You might need to drop me a bone on that one... I've thought for a while that corner speakers are the best approach in a small room - currently experimenting with/listening to monitors pushed into the corners of my study. The actual size of the speaker should make no difference.... I think... soo.. what is it about the size of a large speaker that would be an advantage in small rooms (instead of merely irrelevant)?
Now of course, large speakers tend to extend lower, many being reflex designs, to have flat free space response, which is usually disastrous in a small space. So in that sense, small is often better. Not by design per se, but by the consequential limitations of physics of small (passive) boxes.
If you can fit wider narrower-directivity speakers in the corners of a small room, that would likely be a good bet.
I heard a fair amount of that at last weekend's Sydney Audio Show. A few vendors commented on room acoustics, and in one room a perceptive bystander (I assume) piped up "but this room is probably what a lot of people have for their listening room." And that did get me wondering - why don't speaker manufacturers design speakers to work in the spaces that people actually have? Yes, there will be compromises but a speaker designed to work with the limitations of a real room/placement will surely fare better than one designed for an ideal situation that is then placed in a compromised situation....
There used to be corner speakers and on-wall speakers. But you don't see them any more (except for HT surrounds). Yet when a non-audiophile asks me about speakers, it turns out that that is where they are going to put them...
My point there is that an ideal dipole response is symmetrical, which is more feasible with planar drivers than cone drivers. (Yay, back on topic! )
See the dilemma?
Laterally for sure, it's easier to do with planars, though it could also be done with multiple cones of similar radiation dimensions.
I don't understand what the last dozen posts about speaker size in a small room have to do with the LX521.
I'm not sure I follow... are the cones facing both ways? My measurements show poor symmetry with cone drivers front relative to back.
The crossover/dsp unfortunately doesnt look any cleaner for the signal path...
