0 Members and 1 Guest are viewing this topic. Read 12482 times.
Hi Bigload,I'm new to the forum and new to the Salk family. I just took delivery of a pair of SS M7s from Jim and I'm exclusively a 2-channel music listener. Perhaps my experience will help. My M7s are rear ported and I'm set up in the living room of a fairly large 1 bedroom apartment. I have the M7s placed roughly 2 feet from the wall. Don't forget how important placement is for bass reinforcement, especially in a corner!To my ears the 42 Hz -3db specification cited by Jim for the M7s is probably pretty accurate. Also a tightly damped 42 Hz, again subjective. Personally, I wouldn't consider my M7s without subwoofer reinforcement and that's exactly what I do in my system. I supplement my M7s with a REL R205, very carefully integrated by trial-and-error to my taste. A bit of advice, if you choose a subwoofer for your M7s be picky about brand and model. The majority of subwoofers are designed for HT shock and awe use - which is perfectly valid - but I can assure you only a fraction are tonally correct for high end music reproduction. I'm partial to REL for that reason because of a lot of experience with subs for monitor reinforcement. As always, your mileage may vary.I've attached a photo of my M7s installed in my system for grins. You can see the subwoofer in the right corner. This pair is finished in glorious African Bubinga personally selected in coordination with Jim right down to the vender and lot #. My poor photographic skills don't come close to doing justice. I can post better pics if members are interested in seeing how a current lot of Bubinga from Salk turns out.Cheers!
-ricardojoaFirst, thanks to all for the compliments and interest.The McIntosh unit you see in my rack is in fact a MR-85 tuner. I live in Chicago where we're lucky enough to have one of the finest 24/7 classical music stations in the country: WFMT. On a good day (typically weekends when RF traffic is minimal), analog broadcast with my MR-85 approaches reference quality. That's how serious this audiophile is about broadcast FM.A summary of my system for comparison to the mix of components you may be thinking about:Analog:Avid Diva SP II turntableSME 309 tonearmClearaudio Maestro cartidgeMcIntosh MR-85 tunerDigital:PS Audio PWD DAC fed by NAS storage, nearly all 96/24 or better high-resolution source files (FLAC only)Electronics:Aesthetix Calypso line stageKrell S-275 power amplifierLiberty Audio B2B-1 phono stageMisc.:Furman SPR-20i AC regeneration (the only 'power conditioning' I accept as beneficial for a high-end music only system)SolidSteel racksSound Anchors stands for the M7sREL-R205 subwoofer for bass reinforcement of the M7sAll audioquest interconnects (DBS) and speaker cables, I run my system mostly balancedAudience powerChordsJim has always said his SS series does justice to the best front end gear and electronics. Believe it!For those thinking about veneer choices, I've attached another closeup showing what Jim was able to do with the Bubinga lot he and I chose for the project. Again forgive the horrible flash glare, but I'm pretty sure you get the idea - how eye-popping this recent Bubinga finish turned out.
The stands appear to be Sound Anchors.
-mr_billThe Harbeths are more forgiving than the SS M7s. Subjectively richer in the lower midrange and upper to mid-bass. That's characteristic in my experience of all the British BBC LS3/5 specification inspired constrained thin-wall designs (a deliberate design decision by Harbeths Alan Shaw, also Spendor, Rogers, etc.). The M7s are ruthlessly unforgiving of flaws in upstream HW and source material. Extended high frequency response and a subjectively leaner balance throughout the midrange and down to bass cutoff.The Harbeths really shine with human voice and certain other types of material such as small jazz ensemble music. The BBC monitor specification was, after all, intended to produce a better design for broadcast monitoring use. The M7s really roll with demanding wideband material where the RAALs kick-in. That's the only knock of any consequence I have against the Harbeths - an overly polite high end - but that glorious midrange compensates.I love both for different reasons. Suppose I'm lucky in that I have another set of electronics, so I can mix-and-match my C7s and my M7s. I can tell you the same mix of upstream gear doesn't work for both. Haven't decided yet, but considering rotating my Krell for pure Class-A amplification (which I have) to run my M7s. A bit of Class-A sweetness (which I hear every time in Class-A amplification) might make already really fine into extraordinary.Ciao!
