Solid state amp question
steve f
« on: 28 Oct 2012, 02:56 am »
The solid state amp looks very interesting. I was wondering if it was based on Icepower, Hypex, or some other module. Would you please write a bit about it? So many class D amps go for absolutely huge wattage that they are impractical overkill for most speakers. Nightshade Audio has made a practical design a reality. Oh, by the way,  can the on/off switch be moved to the front? Thanks.
Steve F
Niteshade
    • Niteshade Audio
Re: Solid state amp question
« Reply #1 on: 28 Oct 2012, 07:53 pm »
I have been using either Class D audio or Sure's boards. The power supply, wiring and enclosures are custom made.
The power switch can be move up front and these can be made with integrated inputs as well.
Note: I will be working on an active integrated tube front end for these too.
timind
  • permanent vacation
« Reply #2 on: 28 Oct 2012, 09:21 pm »
Now that sounds interesting.
Niteshade
    • Niteshade Audio
« Reply #3 on: 1 Nov 2012, 09:54 pm »
While cleaning up the old shop, I found a couple of nice, hefty transformers for a 250/channel Class D modules. I have a feeling a tube front end will be installed in both these amps. For now, I am working on a new look for them.
