0 Members and 1 Guest are viewing this topic. Read 15849 times.
That is incorrect. Higher mass materials transmit energy more efficiently. The bit about resisting acoustic feedback is also false as far as a universal statement. High mass deigns can be designed to reduce feedback but being high in mass does not guarantee that. It does guarantee high material costs.-Bill
Wayner, with your AR TT, do you hear artifacts you attribute to skating? Had a friend years ago who had one but my "ears" weren't as experienced then.
I'm a Rega owner of a blown out P5, a fair amount of $$ invested, there are no more upgrades. It does sound great.With that said, I agree about the overpricing on that table for what it is. It should be made out of a Carbon Fiber honeycomb for that price. Wait for a used one if you must have.Around $3k I start looking at something else and I would never spend that on a Rega.Oh, and I have no problem cleaning records with a Disk Washer brush on it because of the motor slowing down with my dual belt pulley or not.Wait! I have to go check my money tree in the back.
I couldn't be more wrong? Gandy now cleans records and supplies height adjustment? Relax, the only part that was a joke was the reviewer friends quip, and that was kidding on the square. As a reviewer you see the schmooze side of the industry. Your defending Gandy, is proof that subjective reviewing can't be objective, especially when you have friends in the mfg biz and you're reviewing their products. Are you personally friends with Harry or any other table mfg? I know, we've been through this before and you can dance around the subject all you want, but it doesn't change the psychological reality of subjective reviewing. It's not always about advertising dollars or pounds, as the case may be, Rega is big enough that they'll get the reviews and promotion anyway. When he first started he offered relatively high performance products for budget money. What's not to like? High end pretensions are something else. Rega's approach or design philosophy isn't even his. Nothing new here - the low mass approach was championed by B&O, a long time ago. Ever read their white paper? It's much more interesting than the table design philosophy on the Rega site. Never the less, it didn't succeed - not because it's so bad, because when guys want to upgrade, they see it's not a viable option at the top. It's no coincidence that all of the state of the art tables for over thirty yrs, are high mass. It's not about good and bad, it's about good and better. Ever play with a Goldmand or Thorens Reference or other state of the art contender? A high mass plinth absorbs vibrations and converts them to heat, it resists acoustic feedback. If sound pressure waves can knock down the walls of Jericho, what about symphonies at realistic levels in your listening room? I know you're aware about benefits of heavy platters. Light platters sometimes have superior PRAT only because of drive system limitations.The first VPI arms used wire tension to apply anti-skate. They now come with adjusters.Of course every mfg thinks their approach is best, except for compromises - usually due to budget considerations and price points. I own neither Rega or VPI tables. I usually prefer DD/rim drive. Peace,neo
I know most of the turntable mfrs. now.I own 15 turntables at present, so I can't say we're any more in love with one or the other. I'm not defending Roy at all. He's told me to my face that he doesn't think reviews make a bit of difference in their sales or their products and he thinks most reviewers don't know a thing about hifi or audio. All the Rega stuff is a matter of refinement. You can look at a P3 as a P9 built on a tight budget, or you can look at the P9 as the best P3 Rega knows how to make. No one has a terribly original design philosophy when it comes to a turntable. It's a motor of some kind, a platter of some kind and a way to couple the platter to the motor.With lots of variations on the theme...
IMO it would be nonproductive to continue the subjective/objective thing, so I won't. Rega record players have their strong points at their price, just as B&O did. Rega probably has a better "value" table. B&O made some outstanding carts. There may be nothing new under the sun when it comes to record players, except refinements and innovations. We're in the midst of a revival, which I suspect may last for decades. Some people may scoff, but there are billions of records already out there and it's a palpably rewarding, and fun hobby. Since the demise of Japanese turntable mfg, direct drive and idler/rim drive pretty much went by the wayside. My Goldmund DD had a JVC motor. I noticed you highlighted the Continuum Criterion in the mag. That company already received some heavy duty accolades which I'm sure it needed to survive at that price. There are two companies which are under reported which might be much better value products. One is Teres, who now makes DD exclusively. The other is Trans Fi, which seems to be a little more well known. Teres tables start at $10K, not cheap but not $60K. I think Trans Fi table is $2K pounds w/o arm. It might be difficult to get review samples, but if doable, I'm sure it would be of interest to numerous hard core fanatics, and the curious. neo
Thanks for bringing up Trans Fi, I'm going to ping them and see what their story is...That arm looks awfully weird.
If you still have that Atlas you could slap that on there. I never heard one, or the table. The table is pretty cool looking IMO. The arm looks like it was built by Rube Goldberg himself or Rube Jr gone berserk with an erector set. It must sound great, looking like that. The ET 2/2.5 is some stiff competition (to continue suggestive allusions). I have heard the ET and it has killer potential, no exaggeration. It now has a low pressure option and VTA on-the-fly with a curved support that maintains tangent setting. neo
Thanks Tom, I'm very intrigued with that table. And Neo, I've got a freshly rebuilt ET2.5 w/carbon fiber arm tube being mounted to a VPI Classic at the factory right now. Can't wait to hear that combination! Always loved that arm.
