K6Davis,Also, upsampled DSD128 works fine, but as I noted a couple days ago I am not using that function realtime, but instead I had JRiver convert some favorite PCM to DSD128 offline. If your server has enough horsepower, go for on-the-fly, but be aware the PCM-to-DSD128 process is VERY cpu intensive. In a single pc setup (where JRiver and the dac driver are on the same machine) I'm not sure what kind of sonics you'd get with a cpu working so hard.Stay tuned.
I will definitely be setting up JRiver to upsample to DSD.
I have seen this mentioned multiple times. Do you upsample everything to DSD one song at a time or can you set it up for everything? If everything where in JRiver do you setup?TIA
It's a setting in JRiver that will do it for all (if you want).See here
I'm just starting to look into the world of Audio PC optimization. My impression of the Dual PC concept is that the installation on the Audio PC is ultra light (something like OS & JPlay), while the Control PC is a more typical OS installation, running your playback software and (perhaps several) other things. My question is: How can the Audio PC improve upon what is the presumably dirtier signal coming from the Control PC?It seems like the weakest link in the chain (the least optimized of the two PC's) would determine the effectiveness of the whole Dual PC setup. If that's the case, it would seem to make more sense to run just one machine and optimize that. I'm hoping there's something about this that I don't understand, because I'd love to have my Control PC upsampling to DSD128 in JRiver, while still reaping the benefits of low resource optimization in the Audio PC. Is that really possible?How is two better than one?
You are streaming jplay? I'm specifically talking Jplay, as that is what k6davis asked about..my dual pc setup. Jplay takes some cpu cycles and my recommendations are an i7 or Xeon equivalent as a single pc or as an audiopc; the controlpc can be smaller (but my Caps V2+ is too small for DSP, upsampling, etc) but again, if you are asking it to do multiple things including DSP I'd get an i5 or bigger. If you are talking generic streaming, then of course an i5 is plenty...hell, I streamed on a tiny Atom processor in my Alix Linux box. But the sonics are NOWHERE near what I am getting with my duyal pc Jplay setup. YMMV.
Yes, audiopc is headless, has no access to the internet and I access it through the controlpc via remote desktop. It runs jplay, the Os and the DAC driver. It is connected to the controlpc via Ethernet cable (controlpc needs two Ethernet connections so one is mobo and one is NIC card) and has an audiophile grade USB card for the DAC..I use Paul Pangs version one card, separately powered via linear.I may start a separate thread about all this. We are getting a little off topic.
i am interested to know about it...please start a topic
