Pass thru for the PCM Dac output! That is how it piggybacks on your old Dac. Ted did say he hopes its transparent!
NuForce released their Icon DAC which supports DSD and Android...$299Has anyone tried this?
Matrix has finally made a silver version of the X-Sabre ($1099). These are the first pictures available (taken by the US distributor). No official pictures are available yet. They said that they wanted us to have the first look. It is a satin glass bead finish (fine sand blasting), with medium gray silk screened letting. The whole unit is the same color, the top looks darker in the pictures but, that is just shadowing. Other then the color, there is now a recessed switch on the bottom to change between 115 volts & 230 volts.Edit: changed $$ to $1099
They are on my list to visit at RMAF but didn't get to their room (1104) today.
Also check out the Avatar Acoustics room. They should be showing the new $159 IFI Micro DAC that plays both DSD and PCM.
The BDP-105 uses an older version of the XMOS hardware, so it is not built into it. OPPO still hopes a software solution may be created, but likely this is a hardware limitation.
The Tascam DA-3000 is finally hitting the streets at $1000. One persons comments said that it did better recordings than the now discontinued Korg 2000 ($1800). This is great news in that it can record all PCM and double speed DSD and play them all as well. So, you have a high rez DAC and a high rez recorder....all for a grand. I am sure it is not as good stock as an AD recorder as the $4000 Ayre unit but with mods it might compete (and the Ayre is not a player). The mono running DACs with my discrete fet IV stage would be killer. Can't wait to get my hands on one.
Scot got around to posting a very good and lengthy "first listen" on the Lampi DSD-only DAC. He, err, LOVES it. http://parttimeaudiophile.com/2013/10/22/lampizator-dsd-dac-first-listen/I get it next.
