Wisnon:I do live fairly close to Ted. No, I have not heard the Chord with the Hynes PS. Ted would be better suited to answer your question on the Qute DAC as he too has, I believe two Hynes PS's. One of them being the SR3-12. I would have assumed that he probably has tried the Chord with both stock and the Hynes' PS.Regards,Randy
for some lucky backers they could get a DSD dac for 99$...down the link it shows it supports DSDhttp://www.kickstarter.com/projects/gavn8r/geek-a-new-usb-awesomifier-for-headphones?ref=liveV
I look forward to comments on the low priced DAC because it could be a game changer. I also wish they would post more specific performance info.
There is a bit. http://mustgeekout.blogspot.com/2013/08/geek-vs-others.html
BTW, George K. over at Exasound is shipping back my updated E20 DSD DAC. As soon as I break it in for a bit, I will be reporting back to all of you on the upgraded MKIII E20.Regards,Randy
Sort of how lowering Cholesterol level below and arbitrary benchmark with statins actually do more damage faster than doing nothing at all.
