DSD DACs
ted_b
Re: DSD DACs
« Reply #220 on: 29 Mar 2013, 04:51 pm »
Forgive me if I'm missing something, Ted, but I thought you (and many others) favoured listening to music in its native format? With these DACS, presumably
one can't listen to any PCM files in their native format? Wouldn't it be better to have a DAC where any up sampling/conversion is optional?
The native format is preserved on output to analog.  It's just that it is not a NOS DAC.  All non-NOS DACs (90% of whats out there) upsample/oversample internally...kinda like making sausage...you don't wanna know what they go through.  I prefer they do their thing via DSD than via some sort of delta-sigma work.  The opposite would be those DSD-capable DACs that ttake DSD and do a lot of internal processing with multi-bit processors then convert back to DSD.  It's not PCM-to-DSD mind you, but it is less stright forward than NOS (non oversampling).
I am thinking of doing a paper with Jussi Laako from Signalyst; a sort of Dummies Guide to DAC architecture.  He is the tech, I am the dummy to translate to us audiophools.  The tradeoffs about ladder DACs, ring DACS, sigma-delta, 1 bit..how they do PCm and DSD...what is NOS....etc etc.
PhilipAC
Re: DSD DACs
« Reply #221 on: 29 Mar 2013, 05:15 pm »
I can see that DSD is preserved, but if a PCM signal goes into the DAC and gets converted to DSD128 before being converted to analogue, how is the native PCM
being preserved?
PS Your paper sounds fascinating!
PhilipAC
Re: DSD DACs
« Reply #222 on: 29 Mar 2013, 05:19 pm »
I'd have to hear it to believe something with that much going on inside it isn't compromised.
But the new Matrix has similar specs to the TEAC, and you and your pals thought it sounded great, as far as I can tell?
I'm not trying to be clever- I ask because I'm shortly going to choose between the TEAC and the Matrix as a short-term option.
wisnon
Re: DSD DACs
« Reply #223 on: 29 Mar 2013, 07:16 pm »
A poster (Valenroy) who has it and the Mytek says that while its so-so on PCM but equal to the Mytek on DSD.!
wisnon
Re: DSD DACs
« Reply #224 on: 29 Mar 2013, 08:33 pm »
Maxvla
Re: DSD DACs
« Reply #225 on: 30 Mar 2013, 04:08 am »
The X-Sabre is very well shielded and does not include an amplifier in the same box. The inside of the TEAC looks like a computer case and we all know how well those are shielded.
Maxvla
Re: DSD DACs
« Reply #226 on: 30 Mar 2013, 04:09 am »
Group of my friends (not local) had the Mytek to demo and thought it was quite bad, so for TEAC's sake, I hope not.
wisnon
Re: DSD DACs
« Reply #227 on: 30 Mar 2013, 09:23 am »
The Mytek is very well described in Monster threads at Comp Audiophile as well as here. Ted has one and so does Mike (who won one from Tone Audio). The feedback on DSD playback has always been good.
When you say the Teac has an amp inside, do you mean a Headphone amp? Shielding seems OK from the pictures as I see STEEL separating the power system (not CNC machined from aluminum as in the case of the X-Sabre) from the Digital section. Dual mono power supply should ensure top notch clean/stable power.
Audistream reviewed it well: http://www.audiostream.com/content/teac-ud-501-dual-monarual-pcmdsd-usb-digital-analog-converter
quicksound
Re: DSD DACs
« Reply #228 on: 1 Apr 2013, 07:55 pm »
After taking a look at the DSD Database table (https://docs.google.com/spreadsheet/ccc?key=0AgVhKcl_3lHfdFVyenBBNjNpQ2lieG81WGpqQTNfVUE#gid=0), can someone explain how the Wyred4Sound DAC2 is DSD64 and DSD128 compatible? I looked at the Wyred4Sound website and they don't mention DSD playback under the "features" section for the DAC2 - you think they would emphasize that point if it were in fact true.
ted_b
Re: DSD DACs
« Reply #229 on: 1 Apr 2013, 08:23 pm »
I think it is a mistaken entry.  I don't do all of them; someone claimed that DSD was available through I²S (like other SABRE dacs) but I have no substantiation.  Good find!  I will correct it if I find no info.
Maxvla
Re: DSD DACs
« Reply #230 on: 2 Apr 2013, 02:52 am »
The Matrix X-Sabre is listed at $1299, but actually sells for $1099, it is also now shipping.
ted_b
Re: DSD DACs
« Reply #231 on: 2 Apr 2013, 03:50 am »
Fixed it....thx
quicksound
Re: DSD DACs
« Reply #232 on: 2 Apr 2013, 11:23 pm »
Has anyone had the chance to compare the Chord QuteHD and the Sonore/exD DSD DAC? Any information would be greatly appreciated. Thanks!
wisnon
Re: DSD DACs
« Reply #233 on: 2 Apr 2013, 11:28 pm »
Audiostream has just reviewed the Auralic Vega and is raving. 6 Moons did a part 1 review with the conclusion yet to come.
ted_b
Re: DSD DACs
« Reply #234 on: 2 Apr 2013, 11:51 pm »
Soon will have the Chord, and I kinda remember the exD.  :)
wisnon
Re: DSD DACs
« Reply #235 on: 3 Apr 2013, 11:43 am »
Interesting excerpt from the NOW COMPLETED 6 moons review of the Auralic Vega:
"The DAC's power supply was revised several times to meet true bit-resolution requirements. The most difficult part during this development was figuring out how to best harness the ES9018. Its datasheet is an error-riddled nightmare with lots of vital information missing. We would like to openly thank everyone on diyaudio.com for their help on how to wring the most performance from this freaky chip. Another big event during development was the added support for DSD. It's actually no big deal to modify software code to support the format but hardware—especially analog circuitry—had to be completely redesigned to suit DSD's sonic character. From that perspective I very much doubt that any DAC which adds subsequent DSD support via a basic firmware upgrade will offer comparable sound. The Vega was designed from the ground up to optimize DSD playback."
mav52
Re: DSD DACs
« Reply #236 on: 3 Apr 2013, 01:31 pm »
Soon will have the Chord,   :)
I'm looking forward to that review
rklein
  • My finest audio piece ever!!
Re: DSD DACs
« Reply #237 on: 3 Apr 2013, 02:21 pm »
I think that it is a very good thing that so many affordable choices are becoming available in regards to DSD capable DACS.
I have to say that I am extremely happy with how my Exasound E20 DAC has broken in.  :thumb:  While there are numerous reports about the DSD playback quality of various DACS, I would like to share that the E20 is the best DAC I have had in my humble system regarding Redbook as well as HiRez material.
As much as we talk about DSD (don't get me wrong...I am a HUGE FAN - thx, Ted  8)), the fact remains that RB material makes up more than 95% of my music library and at $2,500 the E20 holds it's own very nicely.
Randy
wisnon
Re: DSD DACs
« Reply #238 on: 3 Apr 2013, 03:07 pm »
very good Randy.
I love my Lampi G4 L4 for PCM and the Chord for DSD and PCM too.
PhilipAC
Re: DSD DACs
« Reply #239 on: 6 Apr 2013, 09:16 am »
Well guys, I received yesterday my new Auralic Vega. It is obviously not burnt-in yet, but it already sounds wonderful. Not surprisingly, it is very good on DSD,
but I'm sitting here listening to Martha Argerich in her CLASSIC recording of Rach 3-quite old RBPCM- and it is stunningly good.
It is going to take longer (as it burns in) to decide whether it is as musical and emotional as my Vertex Aletheia NOS R2R DAC, but my goodness it has made
a fine start!
