0 Members and 3 Guests are viewing this topic. Read 210819 times.
Tyson provided me with SACD ISO files. I used Ted B's program to extract a stereo DSF file for each track from the ISO. Jriver tags and plays the DSF files, using DoP to send DSD to the Benchmark DAC.Russ
limitations of the USB 2.0 protocol to transmit a DSD signal
Guys, first off DoP does NOT require any creating of files, it is a protocol. Second, it is in fact native DSD that is passed (said for the hundredth time)not a PCM conversion. Third, when you get DSD off the disc it is called ripping just like when you rip something else from a disc. When you extract DSF files from the ISO it is called extraction. Jriver can play either of these (the isos or the dsf files) with no intervention, no creation of "DoP files" etc.No it is not complex, it is straight forward.DSD, native and unconverted, gets to a USB DAC via either a native ASIO driver or via DoP (which is an unobtrusive automatic protocol that carries DSD within the first 16 bits of a 24/176 PCm container). This is not PCM conversion...nothing is converted, and the user does nothing.
That is what the term "ripping" literally means: ripping (as in "separate" not "destroy") a disc's digital contents into individual tracks.
That is what it has come to mean relative to digital audio, but the term "rip" was originally adopted from the digital graphics sector to describe the process of producing a file that is in a format usable by an endpoint device, and literally stands for Raster Image Processor - software or embedded firmware that inputs a vector graphic file and creates a bitmap file that printing devices can use.Steve
Guy's a little clarification would be most appreciated.Russ is talking about listening to the DSD file version of that Pizzarelli SACD but, Rob, you are talking about checking out that SACD...or did you mean "file"? I gather Meitner transports can pass native DSD from SACD (through a propriatary optical link) to their DSD capable DACs (like yours, Rob), is that your situation and , thus, the checking for that Pizarelli SACD? Now, if we are actually dealing with a DSD file --or files-- Russ, could you please be more specific, was it a downloaded DoP file (from where?), or some rip from the actual SACD using a suitable Sony Play Station, or was it some other way to stream DSD natively from computer?Thanks and cheers,Mario
The SACD disc was protected for eons and now someone has come up with a way to rip the data from it in a usable file format .isoIso files are directly playable and have ripped 40 so far and not extracted a single one, as I find no compelling reason to do so yet!That for me is the definition of ripping and in this subset of digital audio, IT HAS COME TO MEAN JUST THAT! The people who introduced the process get to name it.You rip an .iso file and you extract a .dsf file from it of desired.
Mario,Edit: by checking it out, I mean looking at it on amazon and listening to the preview tracks. If I like it, I'll buy it. I have a PS3 capable of ripping the SACD layer, so that is how I would get this SACD's DSD material to my DAC. Also, here is what Wikipedia thinks of ripping: http://en.m.wikipedia.org/wiki/Ripping
Wow, wisnon, what a proclamation. I am not going to argue with you, just refer you to Ted_B's own words in a Computer Adiophile's thread (which echoes plenty of similar references to the meaning of ripping SACD's in that and other relevant forums:"The only way to rip SACD's (to extract true DSD from them) is via the "hacked PS3" method described and discussed heavily here. http://www.computeraudiophile.com/content/SACD-ripping-using-your-PS3-part-2"As you can see, according to Ted's quoted statement, to rip a SACD is to extract true DSD files from them. Totally in line with conventional wisdom. So, if, as you say, you have not extracted any file yet from those ISO images you have in your possession, then, according to Ted, you have ripped nothing. All you have is a collection of ISO disc images that you created (or somebody else created for you). Now, if Ted decides to humor you and changes his statement to endorse your proclamation, then, out of the respect that he deserves for his hard work on this matter, I will gladly humor him and also endorse that proclamation.Peace....................Mario
Yes, please use these terms or stop posting about SACD Ripping to
This isn't Russia. Is this Russia? This isn't Russia.
