Dampening
gary schwob
Dampening
« on: 18 Oct 2012, 08:26 pm »
I have a Virtue 1.2 with Auricaps, which have owned for several years. I have been very
pleased with the sound of the amp, but wonder if anyone has used blue tack or other damping
material in this amp. If so, where did you use it, what did you use, and what was the outcome.
Always looking for ways to get a "little bit more" out of my system, but did not want
to spend much money. Also, concerned about any heat dissipation issues in
possibly doing dampening.
« Last Edit: 18 Oct 2012, 10:09 pm by gary schwob »
Tarzan
  • Virtue Audio Fanboy
Re: Dampening
« Reply #1 on: 19 Oct 2012, 11:57 am »
Yes Blu- tac is a good damping agent, but in the Virtue manuals it states that you can use 1" hobby magnets to much the same effect- l started a thread regarding the subject :).
