Industry Circles
Bryston Limited
Bryston BP-26P
Bryston BP-26P
0 Members and 1 Guest are viewing this topic. Read 1177 times.
turnovertherecord
rain,fog,snow,sun,known to happen on the same day
Bryston BP-26P
16 Oct 2012, 11:17 pm »
I have a tv satelite digital box cisco 8642HD(rogers in canada)on the back of the box there is optical,coaxial and analog out,which one should I use,,,also what to connect to on a BP-26P,which input?
srb
Re: Bryston BP-26P
17 Oct 2012, 01:18 am »
If you have a BP26-P (with phono module), there is no internal Digital to Analog converter and your only choice would be to use the analog outputs out of the satellite box into any of the single ended (RCA) line-level inputs on the BP26-P (just not into the low-level phono inputs).
If what you have is actually a BP26-DA (with DAC module), I would connect the coaxial digital output of the satellite box into one of the two digital coaxial inputs on the BP26-DA. There are no optical inputs on the DAC module so you could not use the optical output of the satellite box. You could use the analog outputs as in the BP26-P above, but it is likely that the internal DAC in the BP26-DA would be better sounding than the internal DAC in the satellite box.
turnovertherecord
Re: Bryston BP-26P
Reply #2 on:
17 Oct 2012, 01:25 am »
what about the cd player dac cambridge 840c
Industry Circles
Bryston Limited
Bryston BP-26P
