0 Members and 3 Guests are viewing this topic. Read 94218 times.
Hi Ray, I'd be glad to stop over with powercords, ICs, and the USB cable we used when you brought your music server to my place. Best, Robert
Hi guys, Well the beautiful room you see above is COMPLETELY TRASHED after last week's disastrous flooding here in Shaker Heights. After the drains backed up, we had four or five inches of standing water in the entire basement, which destroyed the carpeting and subfloor. Fortunately, the electronics were on a rack and did not get wet. The bases of the speakers were somewhat damp, but not too bad; I got them out of the basement as soon as I could and then took the low end drivers out and felt around inside the fiberglass insulation at the bottom of the cabinet. It was mostly dry, as were the terminals underneath, which I unscrewed and let air out. I have yet to hook them up, but I'm assuming (hoping) they work. The primary damage was to my record collection, which was stored in three levels of plastic square shelving. Unfortunately, the entire bottom row, which included all of my rock and jazz records (I had maybe a couple of hundred), got hit hard. I took all of the albums out and dried them off, but the jackets and sleeves sucked up water like a sponge. I'm going to buy new sleeves. Most of the jackets are still functional, but the majority are cosmetically wrecked. What a bummer. Fortunately, all of my classical LPs (about 300 or so) did not get wet at all. On a completely different note, I did score this morning at a neighborhood estate sale. I picked up a Magnum Dynalab FM tuner for $5 and a Thorens TD 320 turntable for $100. It has a Grado cartridge with no stylus on it, so I'm not even sure if it works (although it turns on and the platter spins, so that's a good sign). My plan was to put my Ortofon OM Super 20 cartridge on it; I'm assuming this would be an upgrade from my NAD 533, but I guess we will see). I have no tools, gauges, protractors, etc. to set this thing up (for that matter, I have no knowledge of how to do it either), so I could use some help. Are any of you NE Ohio guys out there turntable gurus? I'll buy the beer (AFTER cartridge is adjusted)
Hey Ray, you can borrow my Virtue One if you want to, I'm not using it.
