Quote from: Kim S. Water got into the connections and with the SST shorted them out cutting the signal completely. After I removed the SST there was no problem. Yeah, this is why I am not rushing to try SST. All the reported sonic gains are tempting. But the fact is, it can, and does cause problems. There's a guy up the road who caught one of his Piega Limiteds on FIRE after an SST application. Whether that was his fault for not applying it correctly, I don't know, and am not willing to guess.
Assuming this is the same "Piega guy" that posted this difficulty on Audio Asylum, he quickly retracted his assertion that the difficulty was caused by Walker SST as originally presumed.
Quote from: WellfedAssuming this is the same "Piega guy" that posted this difficulty on Audio Asylum, he quickly retracted his assertion that the difficulty was caused by Walker SST as originally presumed.No doubt. After I realized that I was going to have to file an insurance claim, and the manufacturer wasn't going to eat the cost of my tweaking fun, I would have tried my best to delete that post too.
It's pretty clear man from Walker's site that this CAN happen. So why argue about it?
Here is another alternative to paying $70 for Walker SST:http://www.2spi.com/catalog/vac/silver-filled-grease-techdata.html">Silver GreaseI might try this stuff out to see how it does. It is supposed to help conductivity.
Hi EProv! As near as I can recall, these are the supplied instructions:http://www.walkeraudio.com/sst.htm
it doesn't appear that hard to apply properly.Hmm...a bit spendy for me tho.Are tube pins the single best place to do a test for maximum benefit???BR,EP
It would be an interesting discussion if the two products were the same but branded differently. However, I'm not quite sure they are indeed the same product. If there is a source within either company that can provide a definitive answer, or if someone else can, I'm sure followers of this thread would be interested.
Quote from: heavystarchHere is another alternative to paying $70 for Walker SST:http://www.2spi.com/catalog/vac/silver-filled-grease-techdata.html">Silver GreaseI might try this stuff out to see how it does. It is supposed to help conductivity.The mapleshade stuff is actually a lot cheaper. The silver grease you listed is $40 for 6.5 grams.
Np I feel tempted to try silclear, but I must resist somehow. Hopefully I can last a month
Absolutely! It is probably the most important place. Use a very thin coat on about 1/2 to 2/3 of the pin. It will probably take 8 - 10 hours of playing time to fully break-in. Thank you.
