X-static crossover access
doug067
« on: 9 Oct 2012, 11:14 pm »
Anyone remember the quickest way or access to the x-over is?
Danny Richie
Re: X-static crossover access
« Reply #1 on: 9 Oct 2012, 11:22 pm »
Remove the base then the bottom panel. The crossover is mounted on the bottom panel.
doug067
« Reply #2 on: 9 Oct 2012, 11:35 pm »
Thank you! That was faster than looking myself and being disappointed!
nickd
« Reply #3 on: 10 Oct 2012, 04:19 pm »
The down side of crossover removal on the X static is the screws in the soft medite may not re-tighten. That medite they used is very soft and they didn't install inserts. plan on some time and material to repair those screws
doug067
« Reply #4 on: 10 Oct 2012, 11:26 pm »
Yes, thanks for that tip. I can see this panel was not ment to be removed alot? Thanks again!
