I shave in the shower ...The hot water and steam from the shower softens your beard really well....
It takes a great deal of skill to hone a straight razor. Not a job for the neophyte.Doc
Following Devil Doc's earlier advice regarding Badger and Blade, I have been wet shaving with a DE razor for the past several weeks. I'm hooked, and I'll never use a cartridge razor again. The shaves are perfect, cause no irritation whatsoever, make me clear my mind and concentrate, and are now even enjoyable. Thanks, Doc! I got a Merkur 34C razor, some DR Harris Arlington shave cream (smells great), some Derby blades, an alum block, and a Penworks shave brush. I follow up with some Nivea After Shave Balm for sensitive skin. They all work together flawlessly., Plus, it has been fun; from figuring out how to mix a great lather, to figuring out blade handling for a perfect shave every time. The cool thing is that it's a cool hobby, with tons of gear to try - from razors to blades to brushes, soaps or creams. And more. Don't look into it if you like to buy things. But, if you're looking for a great shave, wherein 100 new blades cost about 10 bucks, Doc's advice was outstanding. You should check it out. (There's some mighty fine folks over there, too.)Here's a pic of the shave gear. Have fun,Jerry
