Room Tratement Products
jcoat007
« on: 7 Feb 2003, 04:02 pm »
The room treatment products look like big pillows or sacks.  Do you have any other pictures that you can post to give a better idea of what they look like?  If you have any pictures of rooms that have the treatments, that would be helpful.
What colors do they come in?
What kind of fabric are they covered in?
Can you comment on what they are made of?
WilliamL
« Reply #1 on: 7 Feb 2003, 09:55 pm »
Steve,
Thanks for your inquiry. The Response products consist of a pillow type design which you refer to as well as a design which incorporates a wood frame.
The cloth used is a special acoustically transparent fabric and is generally available only in black and ivory.  Although we can do other colors (namely grey) we usually only do so for big custom installations. Having two main colors helps us keep the cost down and pass the savings on to our customers.
We are in the process of adding a bunch of things to our website, including pictures of home theatres, schools, studios, etc. that are using our products. I just have to motivate the webmaster.  :evil:
Here is a quick picture...
http://www.audiorevolutions.com/images/roomtunes1.jpg">
All products are proudly made in the USA too. :-)
