0 Members and 1 Guest are viewing this topic. Read 118790 times.
Guidof, Thanks for your impressions of the differences in power supply. I've been wondering about that since I first hooked up the AMDC.I have been out of town helping my 93 year old father get ready to sell his house and move. Wait, that makes me really old. I have re-run my calibrations and I am happier with the upper limit set to 250Hz (from 500Hz). The biggest sound improvement I have found was using the Compensation to fill in the mid-bass to bass range. I learned to use the Compensation from a news letter in the AMDC box. I don't know if it is available on the Web.Good luck with your move.Jim
Can you scan and post the relevant section (bass fill in compensation) of that newsletter? Otherwise email me. I can PM the email addy.Thanks
Medium Jim,Thanks, but I need more hand holding then "post it as a URL". Does AudioCircle have a hosting site or do I use one of the outside sites?
As promised, here are my impressions from substituting the AntiMode Dual Core's 9V AC wall wart with a 12V DC CIAudio power supply.The overall impression is of the same order of magnitude and in the same direction as when I substituted a run of Audioquest Cinnamon (ahem) Ethernet* cable for the garden variety cable I was previously using, that is, somewhat greater clarity and refinement, with more detail, more airy and sweeter highs, better defined bass, and in general a presentation one step closer to the elusive goal of faithfully reproducing a live unamplified event. Also, timbres seem more accurate, which contributes to the overall sense of effortless presentation. And the signal to noise ratio seems better (blacker blacks).Yes, the difference with using the wall wart is subtle, which perhaps suggest the standard PS is pretty good. But they are worthwhile. And of course, at $350, the CIAudio supply is about one third the cost of the Dual Core, so one would have to consider this before opting for the CIA. Personally, I'm satisfied that the improvement, in my system, justifies the cost.*And of course, we all know that Ethernet cables cannot possibly affect sound quality. Guido F.
