0 Members and 1 Guest are viewing this topic. Read 119788 times.
Even without the codes, I believe it is possible to use a learning remote with the capability to "read" the signal that the DSPeaker remote is sending. A bit more time consuming a process tho...
Anyone using it in place of a preamp? I currently have mine going directly into a Simaudio amp. However, I have the new Primare A34.2 amp coming in and was thinking about buying the matching pre as well. But now, I don't know. The Primare Pre32 is a nice looking piece and would look great in my rack, but I'm just not sure if there will any sonics benefits to having it in the system. Thoughts?
FWIW, I tried the Dual Core as a preamp in my system and found the sound very clean but lacking in dynamics and body. Sort of like the sound I get when using the passive option in my preamp. Not at all convincing.Guido F.
And were the dynamics and body restored when you reinserted your preamp?
Looks promising!
I nominate you to purchase one to compare to the battery power set up you have!
OK, I got it now.....
