0 Members and 1 Guest are viewing this topic. Read 119824 times.
thanks Jim, I will try that later on tonight.
I'm not saying it's a problem, it's something fairly fundamental to these DSP-based units. If someone who had one could measure the frequency response, that would pretty much tell.
Hi ryno, I didn't have a chance to A/B the Gungnir with the DSPeaker Dual Core. The Gungnir was sold and I need to get it shipped tomorrow, but maybe I will A/B just the DAC performance tomorrow before I pack up the Gungnir. What sold me on the DSPeaker was its positive impact on the sound of my system (bass in particular) when using the analog input for my vinyl playback (!). I A/Bed the DSPeaker A/D/A in bypass mode (no DSP employed) with an all analog signal, and while the audition was not very very extensive (where I imagine small differences would probably be revealed), I heard no degradation of the sound (output level was lower through the DSPeaker though, I needed to adjust listening levels with an SPL meter; incidentally this is a good thing in my system, which has a little too much gain overall). Once the DSP was run (via Typical setting) the Dual Core clearly improved the sound. More details to come as I live with the DSPeaker for a little while longer. Only gripe so far is that I haven't had any luck with the Toslink input (which the dealer said was picky). Analog and USB work fine. Hopefully toying with the optical cables will get this sorted out.
That worked! Holy ••••! That is just unbelievably awesome sounding. I am in lust with this sound.
I don't think you can do any better than the Lifatec Silflex Glass Toslink cables. Their cost is based on precision materials and German manufacturing, but without additional audiophile markup. http://www.lifatec.com/toslink2.html Steve
Rclark:Glad it worked out!Jim
I'm visiting Mike at Tweekgeek this coming weekend and perhaps I can run a sweep on his, assuming there is interest.
Hi Mike, I'd be interested, if it's not too much trouble
Anyone using it in place of a preamp?
Yeah, I thought that would be a problem for me too.But it drove my Virtual Mode amp and OzarkToms' TBI MG3 just fine into my Shelby + Kroll 86db into 6ohm monitors.System dependent I guess.
I would say that too much gain is a more common problem than not enough gain, especially if going all digital.
Hi Rodge:Glad to read that you and your family made it safely through Hurricane Sandy.Jim
Though be aware that the volume control and all controls are remote only
