And there is a capable and transparent DAC that can handle up to 24/96 tracks.
I had issues with the optical input in that it wouldn't play 96K material, the 44K was fine.
no, it converts to 40 bit/6100khz or 6.1mhz.
Not a spec I have seen previously in DACs. Usually it seems to be 16/44.1, 24/96, or 24/192. And for the Antelope DACs and others, I have seen mention of 64 bits and 384 kHz capability. Curious that the DSPeaker does not follow along these common multiples of doubling kHZ.
6.144 MHz is 128 x 48 kHz, that's the oversampling rate on the DAC, not the internal processing rate. Given that the TOSLINK output is at 48 kHz, it seems most likely that that's the internal processing rate. wisnon, can you ask them?
I'm hoping I can use this device to hipass my speakers a bit, cut off anything below 80hz
Rclark:If you liked the integration before the Ncores, all that was really required was adjusting the gain on your subwoofer to match the output of your Magnepan's. Having said that, you can leave the sub at whatever cutoff point as before.Jim
Maybe you can't use the xovers with a 2.2 system. In the connection guide, http://www.dspeaker.com/en/technology/anti-mode-technology/anti-mode-20-dual-core-connection-examples.shtmlUnder 2.2, it says you must use your subs xover, not the built in's. probably means you can't use the high pass either.
But could you treat the dual subs as a single sub by using a splitter?
