BDA-2 DAC and BDA-3 DAC
R. Daneel
Re: BDA-2 DAC and BDA-3 DAC
« Reply #860 on: 22 Mar 2015, 02:08 pm »
So far the PCM is 50/50 BDA3 vs BDA2
james
Thank you!
Cheers!
Antun
Grit
  • - Garrett
« Reply #861 on: 23 Mar 2015, 05:49 am »
james
Any expectation that'll change (that the BDA3 will sound better than the BDA2)?
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #862 on: 23 Mar 2015, 10:10 am »
Hi Grit
In blind testing it is a really close call with PCM.  The reason for the BDA3 is to allow DSD and HDMI playback to the mix.
james
Grit
  • - Garrett
« Reply #863 on: 23 Mar 2015, 12:01 pm »
Just making sure I don't need to upgrade my BDA-2.  :lol:
What happens when you send a 5.1 (or any multi-channel) signal via HDMI to the BDA-3? I assume it either uses just the L/R  channels, or it just can't lock onto the signal?
« Reply #864 on: 23 Mar 2015, 12:40 pm »
Have not tried that yet.
james
Rod_S
« Reply #865 on: 23 Mar 2015, 04:05 pm »
Would you ever consider making a muti-channel DAC?
« Reply #866 on: 23 Mar 2015, 04:26 pm »
Hi
Maybe some time in the future but nothing on the horizon at this point.
james
tatcom
« Reply #867 on: 25 Mar 2015, 09:22 am »
it's called the SP3 :D
Rod_S
« Reply #868 on: 26 Mar 2015, 11:08 am »
That would of course work however I was thinking for those who have a SSP or receiver that doesn't have the ability to accept DSD having a multi-channel DAC would be a way around that. But that would of course mean updating the BDP's to output multichannel PCM and DSD in order to feed the multi-channel into a new BDA then from there into the multi-channel inputs of the receiver/SSP.
scirica
« Reply #869 on: 6 Apr 2015, 10:21 pm »
Anyone else refreshing the Bryston home page waiting for the BDA-3 official announcement? I know I am!
Come on James!!
Phil A
« Reply #870 on: 6 Apr 2015, 11:55 pm »
Come on James!!
Patience - I'm sure they are testing it (as indicated in James' posts).  Products with cutting edge technology need a bit more time.  I'm sure it's not far off.  Yes I have checked the website a couple of times of the past month.
bjski
« Reply #871 on: 7 Apr 2015, 01:50 am »
Come on James!!
I have a deposit on a BDA-3 along with a Bot.
scirica
« Reply #872 on: 7 Apr 2015, 02:58 am »
Yes, I am encouged by the amount of testing they are doing to make sure they get it right. I love my BDA-2 and don't want them to rush anything either!
« Reply #873 on: 7 Apr 2015, 10:24 am »
Hi Folks
Yes we used it at the recent Montreal audio show and it worked great for 4 days running.  Just working on the DSD side currently and I am hoping we will be in production in about 60 days.
james
gdbalp
« Reply #874 on: 8 Apr 2015, 03:04 am »
Hey James,
Sounds like another Bryston winner for 2015.... :thumb:
And wondering if the new USB Type - C connector will be used for the BDA-3 and future product developments?  This new connector meets 3.1 USB specifications ( 10gb/s + power) and there is no worries on orientation with male and female connection points...
Ciao, Luigi
« Reply #875 on: 8 Apr 2015, 09:40 am »
Hey James,
Ciao, Luigi
Hi Luigi
We have not looked at it yet but speed is not really required with the BDP 2 as USB 2 is 10 times faster than required for high resolution audio files.
James
scirica
« Reply #876 on: 19 Apr 2015, 04:17 am »
Put my deposit in tonight.  It's not like saving accounts are paying any interest these days, so I might as well "loan it" to my dealer to make sure I get one of the first units.
Grit
  • - Garrett
« Reply #877 on: 19 Apr 2015, 06:56 am »
After doing some reading, it appears the BDA-3 will be controllable via ethernet? That'd be a nice change. My SP3 and BDP-2 are ethernet controllable, as are my Tivo and Oppo. If the BDA-3 is also, I could move to an entirely ethernet controllable system and get rid of the IR sensors!
I wonder why Bryston doesn't usually put the 3.5mm IR jacks on the back of most units. The SP3 has one, but the BDA-2 and BDP-2 don't.
R. Daneel
« Reply #878 on: 29 Apr 2015, 09:52 am »
Hi James!
Out of curiosity - have you tried to make comparisons between high-res PCM and DSD using the same music on the BDA-3?
Cheers!
Antun
« Reply #879 on: 29 Apr 2015, 10:59 am »
Hi James!
Cheers!
Antun
Hi Yes
And it supports my conclusion that the file format does not determine a quality recording.
james
