BDA-2 DAC and BDA-3 DAC
werd
Re: BDA-2 DAC and BDA-3 DAC
« Reply #680 on: 2 Nov 2014, 04:35 pm »
I think it's the same chip utilized differently ^^^
Phil A
« Reply #681 on: 2 Nov 2014, 04:40 pm »
http://www.audioaficionado.org/bryston-audio/28796-bryston-bda-3-announced-2.html
"Hi
I have not done a straight ahead shoot out yet but the only difference is we are using a new AKM DAC which is being used because it will do DSD.
james"
werd
« Reply #682 on: 2 Nov 2014, 04:48 pm »
It's not clear. The existing dac in the BDA 2 does DsD.  I would need to know what AKM dac chip is in the BDA 3 to know for sure.
werd
« Reply #683 on: 2 Nov 2014, 05:17 pm »
Probably is a new chip due to the multichannel mode. I doubt though they will run a dual dac like the BDA 2.
Which would be a bummer.
Phil A
« Reply #684 on: 2 Nov 2014, 06:27 pm »
Here's a list of their DACs - not sure of the differences
http://www.akm.com/akm/en/product/detail/0021/
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #685 on: 3 Nov 2014, 02:03 am »
Yes it is a new AKM DAC just released and there will be 2 used.
james
R. Daneel
« Reply #686 on: 3 Nov 2014, 01:44 pm »
james
Hi James!
This is exciting albeit a bit sudden. I didn't expect to see a DSD-capable DAC so soon.
I have a few guestions:
1) We already discussed the matter of DSD implementation into your BDA-2 DAC and your concern then was that DSD capability would require bypassing of the sample-rate converter which would increadse jitter and compromise PCM performance of the DAC. The obvious solution to this problem, as you explained it, was to have two separate circuits, one dedicated solely to PCM decoding and the other to DSD decoding. My question is: is this approach now being employed in the BDA-3 DAC?
2) Your products are developed on the basis of technological research as well as listening tests. How much would I be benefitting from the BDA-3 over my existing BDA-2 when it comes to PCM playback? Would there be an improvement in audio quality over the BDA-2 DAC?
3) Everyone is talking about BDP-2 and it's compatibility with DSD. How do the things stand with the BDP-1 player? Does it allow same compatibility?
Cheers!
Antun
« Reply #687 on: 3 Nov 2014, 02:01 pm »
Hi James!
Cheers!
Antun
Hi Antun
1. Yes the input section determines the type of signal coming in (DSD or PCM) and routes it to the appropriate circuitry inside the BDA3
2. I do not think you would find PCM sounding much different through the BDA2 or the BDA3. Most of the listening tests seem to support the premise (and has from the beginning of our DAC developments) that most quality DACs are within a hair of each other when it comes to technical performance on paper.  Where the larger issues are is in power supply integrity and type (analog vs switching), discrete analog fully balanced amplification circuit topology (not IC's), electrical noise etc. So the differences when it comes to these design features in the BDA2 and BDA3 are essentially the same.
3. Yes the BDP-1 will allow for DSD playback with the MM software and a USB 2 DAC.
Hope this helps.
james
alexone
« Reply #688 on: 3 Nov 2014, 02:39 pm »
James,
so the hdmi inputs of the BDA-3 are some kind of audio de-embedders??
al.
« Reply #689 on: 3 Nov 2014, 02:50 pm »
James,
al.
No they are standard HDMI connections.  A lot of products now only offer HDMI out instead of COAX - example TV cable boxes. Also DVD players like the OPPO offer SACD output on HDMI which will work with the BDA3.
james
klao
« Reply #690 on: 3 Nov 2014, 04:59 pm »
I that case would BDP-1 output DSD via AES/EBU or SPDIF?  Does the unit has USB out??
Thank you, James.
« Reply #691 on: 3 Nov 2014, 05:00 pm »
Thank you, James.
No you can not legally output DSD except on USB
james
klao
« Reply #692 on: 3 Nov 2014, 05:15 pm »
Sorry, James.  I'm a bit confused.
So, would the original (non-USB) BDP-1 that I have, if updated with latest Manic Moose firmware, somehow plays the DSD files, or not?
Thanks again. : )
« Reply #693 on: 3 Nov 2014, 05:21 pm »
Thanks again. : )
Hi
The BDP-1 has 4 USB connections. USB connections are 2-way so they can be used to receive or send signals.  So connect the DSD DAC to one of the USB outputs on your BDP-1 (reboot the BDP-1) and it will output DSD after you choose the DSD DAC in the MM software.  The DSD DAC must be USB 2 version.
james
klao
« Reply #694 on: 3 Nov 2014, 05:51 pm »
Hi
james
OK, that's clear to me now.  I thought USB connections in the BDP-1 are just one way (in).  Thank you.
The latest BDA-3 has two, how should I call "circuits/paths", one optimized for PCM & one for DSD, as you mentioned before somewhere?
EDITED: Got that.  Failed to read your answer no. 1 to Antun.  :)
« Last Edit: 4 Nov 2014, 06:01 am by klao »
R. Daneel
« Reply #695 on: 3 Nov 2014, 06:30 pm »
Hi Antun
Hope this helps.
james
It does indeed, thank you very much!
Cheers!
Antun
Rod_S
« Reply #696 on: 4 Nov 2014, 05:14 pm »
This talk of multi-channel, where are you guys finding multi-channel downloads be it DSD and/or PCM? I haven't come across any yet thus I've only experienced multi-channel via SACD and DVD-Audio discs.
Phil A
« Reply #697 on: 4 Nov 2014, 05:22 pm »
If you can extract DSD ISO files which have a multi-channel layer, you can extract the multi-channel layer.  I did about 50 multi-channel extracts for a secondary system where I have an Oppo 103D with a hard drive attached to it.
Rod_S
« Reply #698 on: 4 Nov 2014, 06:29 pm »
You mean straight from a SACD? I never thought to do that.
Phil A
« Reply #699 on: 4 Nov 2014, 07:09 pm »
Correct - I use the PS3 to get the ISO file and then instead of extracting the stereo DSD file, I do multi-channel.  A little resource intensive (even though my main PC is about 3 years old it is a 6 core processor with good RAM) but it gets you there.  I did about 50 as I just have a 1TB hard drive attached to the 103D with FLAC files of CD quality, some FLAC files higher than CD resolution, some 2 channel DSD in addition to multi-channel DSD>
