BDA-2 DAC and BDA-3 DAC
0 Members and 1 Guest are viewing this topic. Read 457923 times.
Phil A
Re: BDA-2 DAC
« Reply #640 on: 28 Oct 2014, 07:23 pm »
Was not able to see the pictures on the post above by mav52.  So I guess this will be like the prior DACs but also have an HDMI input?  If so, cool!
joey116
Re: BDA-2 DAC
« Reply #641 on: 28 Oct 2014, 07:49 pm »
$3195 list
Is this technology going to offered as upgrade to other Bryston components... SP3 etc.
alexone
Re: BDA-2 DAC
« Reply #642 on: 28 Oct 2014, 08:24 pm »
James,
i believe that you mentioned in an earlier thread that DSD via HDMI would have some jitter issues. if so, how did Bryston solve this problem with the new BDA-3?
al.
Rod_S
Re: BDA-2 DAC
« Reply #643 on: 28 Oct 2014, 08:29 pm »
Whoa!, what?
Is there a list of specs on this?
  • The Demo is Everything!
    • http://www.bryston.com
Re: BDA-2 DAC
« Reply #644 on: 28 Oct 2014, 08:37 pm »
Hi Joey
We are looking at adding DSD to the SP3 but a ways off at this point.
james
Re: BDA-2 DAC
« Reply #645 on: 28 Oct 2014, 08:38 pm »
James,
al.
Hi al
No way to solve - HDMI is still going to have more jitter than other connections.
james
mav52
Re: BDA-2 DAC
« Reply #646 on: 28 Oct 2014, 08:39 pm »
$3195 list
Well I'm going to buy one, I've been waiting for this one.   :dance:
Re: BDA-2 DAC
« Reply #647 on: 28 Oct 2014, 08:40 pm »
Whoa!, what?
Hi Rod
Will have specs shortly but we are still in prototype stage so some small changes may be happening.
james
mav52
Re: BDA-2 DAC
« Reply #648 on: 28 Oct 2014, 08:48 pm »
I will try to post the 2 pictures
Marius
Re: BDA-2 DAC
« Reply #649 on: 28 Oct 2014, 09:26 pm »
HI James,
exciting news! congrats on the BDA3.
will you be offering options to have more Spdif connections instead of the multitude of HDMI's? Im in need of extra optical nuts already, and have a full set op spdifs on the BDa1, so this BDA3 set would really be a setback....
id love the 10 inputs, but need to have them in different formats, would be wonderful to accommodate that.
Also, since your still in beta, could you provide for a second balanced out?  that way we could feed it to both the bP26 and the BHA1 without any issues, long awaited that one!
Cheers, and again, congrats on an industry leading machine!
Marius
Rod_S
Re: BDA-2 DAC
« Reply #650 on: 28 Oct 2014, 09:31 pm »
Hi Rod
james
Sounds good, thanks James
Re: BDA-2 DAC
« Reply #651 on: 28 Oct 2014, 09:33 pm »
HI James,
Marius
Hi Marius
I do not think there will be 2 AES but we may be able to offer different versions of the SPDIF connections.
James
Marius
Re: BDA-2 DAC
« Reply #652 on: 28 Oct 2014, 10:03 pm »
 :thumb: :thumb:
Awesome!
Please have some extra thought on the 2nd balanced out, and a deal is in the making!
Very exiting this is.
Marius
Hi Marius
James
Phil A
Re: BDA-2 DAC
« Reply #653 on: 28 Oct 2014, 11:13 pm »
Thanks for the pics.  I sent an e-mail to my friend Karl to see if he is going to get one to review for the Absolute Sound (he did the BDA-2 review and I called him when I found out as I was about to pull the trigger on a DSD DAC and wanted to know if he knew if DSD was planned).
Rod_S
Re: BDA-2 DAC
« Reply #654 on: 29 Oct 2014, 12:34 am »
So in reading the posted photos I see that it says DSDx4 natively, how does this relate to using the BDP-2 for DSD then? I know that the BDP does DoP, what was it via the USB?? so that implies a conversion of the DSD signal. In order to keep the DSD native would that mean this is something that can not yet be done via the BDP-2 and we would need another player in order to do that?
Another question, what's the difference between DSDx4 and DSD512 which is also mentioned? Is DSDx4 DSD256? If so does that then mean the DBA-3 can not decode DSD512(i.e. DSDx8???) natively?
It's odd seeing HDMI inputs/outputs on a DAC. To bad my Denon DVD-A1 didn't output SACD at it's native resolution over HDMI, it is unfortunately limited to 16/44.1. The native resolution can only be output via DenonLink or analog.
Re: BDA-2 DAC
« Reply #655 on: 29 Oct 2014, 12:39 am »
:thumb: :thumb:
Awesome!
Marius
Re: BDA-2 DAC
« Reply #656 on: 29 Oct 2014, 12:45 am »
Yes currently the BDP2 does DSD DOP but going forward we will look at other options in software.
Yes DSD512 is DSDx4 (which is really theoretical at this point as I am not aware of any material available)
james
Rod_S
Re: BDA-2 DAC
« Reply #657 on: 29 Oct 2014, 01:07 am »
james
So just to confirm, DSD512 is DSDx4, not DSD256? So many numbers I just want to make sure I understand things correctly :)
Very interesting, I like that you are going to look to see if the current BDP platform can output DSD natively with a software update. My plan was and perhaps still is to get the BDP-2 with my income tax, do you think you would know by tax season if that's doable? I really want the player but would certainly hold off for a BDP-3 so to speak if you discover new hardware would be necessary to pull off DSD native output and it was a feature you wanted to offer customers in a product.
Setting aside DSD native output for the moment, since a USB cable is necessary for that and DOP are all of the PCM resolutions also output via the USB or would one still need to connect another cable (i.e. toslink, SPDIF, AES/EBU) to do the PCM magic?
Rod_S
Re: BDA-2 DAC
« Reply #658 on: 29 Oct 2014, 01:09 am »
One more thing, what version is your HDMI implementation in the BDA-3? If you want to wait to disclose that, no worries, I understand.
Re: BDA-2 DAC
« Reply #659 on: 29 Oct 2014, 01:18 am »
Hi Rod
Nothing planned beyond the BDP2 and I assume any upgrade would be software based as the computing power in the BDP2 is substantial.   No other way to do DSD legally other than USB so do not see changes there either.
james
