BDA-2 DAC and BDA-3 DAC
0 Members and 1 Guest are viewing this topic. Read 458266 times.
Servingthemusic.com
Re: BDA-2 DAC
« Reply #620 on: 30 Aug 2014, 08:49 pm »
I see dsd has risen from the dark ages. Its a start i am sure this time next year it'll be pretty good for DSD availability.
Well you realize that less than 2% of ALL commercially recorded music has been mastered in DSD. Hmmm.
Servingthemusic.com
Re: BDA-2 DAC
« Reply #621 on: 30 Aug 2014, 08:51 pm »
True but that's also not much above most of the high resolution PCM download prices. It's the nature of the business, for those wanting high res the price is adjusted to reflect it and it's not cheap, either way.
There are always discounts available for HDTracks, Qobuz, and Pro Studio Masters. Not so for Superhirez.
The $25 price is not justifed. No manufacturing, no printing, and no shipping costs.
Servingthemusic.com
Re: BDA-2 DAC
« Reply #622 on: 30 Aug 2014, 08:52 pm »
Hi
Try this, i wish i would have when i had the BDA1.
Go in with the appropriate sized torex and release the nut holding down the transformer. Then release the screws holding down the pcb board. About a 1/4 turn each, thats it. Everything comes from manufactures tighten down way to much. Which is useful for shipping but not playback. Remember when cd players had the transport screws? Same thing...
Um, huh?
  • The Demo is Everything!
    • http://www.bryston.com
Re: BDA-2 DAC
« Reply #623 on: 30 Aug 2014, 09:16 pm »
I am specifically separating the DSD DOWNLOAD market from the PHYSICAL SACD market.
I am a big fan of DSD and SACD sound wise. But the files freed from the physical format has been over hyped shamelessly.
FYI, I said DXD is a joke, not DSD. DXD is a manufacturer created buzzword. Period.
And I am sure you know that many, many SACDs and DSD downloads may have spent some time in the PCM domain, or so called
DXD for editing.
Hi servingthemusic
Can you expand on the DXD as a buzzword please.
james
Servingthemusic.com
Re: BDA-2 DAC
« Reply #624 on: 30 Aug 2014, 09:47 pm »
Hi James.
I used the phrase buzzword in reference to DXD as a viable commercial end user format.
werd
Re: BDA-2 DAC
« Reply #625 on: 31 Aug 2014, 12:50 am »
Can't really think of a good reason to do that.  It's an on-chip enable/disable function, it's not like any signal goes through the switch to get degraded.  I think the majority of songs in a library sound better with upsampling bypassed, however for poorly recorded or compressed tracks, upsampling can often make them sound better.
If your dac is a non upsampling dac do you need a Sample rate converter chip? IDK.
« Last Edit: 31 Aug 2014, 02:04 am by werd »
Grit
  • - Garrett
Re: BDA-2 DAC
« Reply #626 on: 31 Aug 2014, 10:08 am »
Hi Antun
There is nothing wrong with DSD over PCM (DOP) as it is still a DSD file. My concern is with the fact that there are other was to decode DSD as well (64, 128, 256, DOP, Native  etc.) and I think a DAC show allow for all versions going forward. Also DSD DACs up-sample to a specific very high frequency all incoming Digital signals so playing a PCM native file is not possible if you are upsampling every signal coming in.
I think the best solution is to design a DAC that has 2 different circuit paths - one optimized for DSD and one optimized for PCM. There are some newer chips coming out that should allow us to do this.
james
And there is the precursor to the BDA-3 :)
Format aside, I'd like to see studios release the music before it was compressed for public consumption.
I'd think they edit songs until they have a perfect copy, then take that copy and compress it for public consumption. Does anyone know if that's the case? If so, it would't really require any extra work on the part of the studios to release them, right?
- Garrett
Re: BDA-2 DAC
« Reply #627 on: 31 Aug 2014, 11:03 am »
Hi James.
OK thanks.
james
R. Daneel
Re: BDA-2 DAC
« Reply #628 on: 31 Aug 2014, 01:37 pm »
Hi Antun
james
Hi James!
I believe that is what I said, converting PCM to DSD inevitably means cahning the sample length and sampling frequncy and as I remember, you mentioned how you are not keen on these techniques but rather prefer to decode each file in the way it was encoded.
One thing to consider is that DSD seems to be available only through USB. In the case you should build a PCM/DSD DAC as a one box solution, the connection to your BDP would have to be USB. As an audiophile, and I am sure many would agree, I would take chip-based hardware of the Envy24 chipset over software encoders in your BDP any day of the week. Just like you, I prefer AES XLR over USB.
Alternatively, USB would eliminate the need for a sound-card on your BDP which would make things less expensive for the customer.
Lots of things to consider but I know I won't be getting a DSD DAC till the format's future is clear. There is a strong chance it will never catch on. The advantage in smaller file size over PCM WAV is irrelevant considering disk space is becoming greater and cheaper by the minute.
Best,
Antun
werd
Re: BDA-2 DAC
« Reply #629 on: 31 Aug 2014, 01:43 pm »
Hi James!
Best,
Antun
The bda2 will play dsd. Or at least the akm chip set does.
werd
Re: BDA-2 DAC
« Reply #630 on: 31 Aug 2014, 02:23 pm »
R. Daneel
Re: BDA-2 DAC
« Reply #631 on: 31 Aug 2014, 02:44 pm »
Hi!
The AK4399 DAC is capable of on-chip DSD conversion but the BDA-2's firmware is not. According to Bryston, doing this would require bypassing the sample-rate converter which would then compromise the PCM processing and audio quality because the SRC is one of the key figures in jitter reduction.
This is why Bryston is thinking of a two-way approach with separate circuits for respective PCM and DSD processing.
Cheers!
Antun
R. Daneel
Re: BDA-2 DAC
« Reply #632 on: 1 Sep 2014, 01:07 pm »
To James or those who know, I would like to know something about the Bryston AES/EBU digital cable. From whom was are the wires sourced? Mogami perhaps? If so, is it the 3080 model?
I am trying to see if there are differences in these cables so I'd like to know more because Bryston's website doesn't say what kind of a conductor this cable uses.
I appreciate your input!
Cheers!
Antun
Re: BDA-2 DAC
« Reply #633 on: 1 Sep 2014, 01:57 pm »
Cheers!
Antun
Its 110 ohm Belden Cable with gold plated XLR connectors or 75 ohm BNC or 75 ohm COAX connectors.
james
speltz
Re: BDA-2 DAC
« Reply #634 on: 21 Sep 2014, 08:16 pm »
 :D I'm delighted to say that I now own a BDA-2, paired with the BDP-1 I purchased nearly two years ago. And I'm loving the results! :D
The most obvious (and I do mean obvious) change is the 3-dimensional soundstage the BDA-2 delivers. In the past, the soundstage from my system was always 2-D -- left to right. This is the first time my setup has ever produced a soundstage with depth, in particular extending back behind my speakers (MartinLogans).
My experience is consistent with the reviews I've read saying the sound is moved back (recessed) with the BDA-2. But it's not a negative when it's delivering that 3-dimensional sense of musical space. The music still has plenty of toe-tapping energy and drive, with both pop/rock and jazz music.
Initially, there was some harshness to the upper frequencies. I was sure the fault lay with my system, which has a tendency to tip into over-bright territory. Yesterday I swapped out the XLR cable connecting the BDP-1 to the BDA-2, and that seems to have solved the problem. I listened continuously for about 90 minutes earlier today with no fatigue.
My old DAC was neither old nor cheap, but the BDA-2 is superior to it, and the differences are not subtle. A subtle improvement is all I expected -- hence my delight with the actual results.
mav52
Re: BDA-2 DAC
« Reply #635 on: 18 Oct 2014, 01:04 pm »
I wonder if there will be a BDA-3  and when and what might this DAC include :eyebrows:
« Last Edit: 18 Oct 2014, 09:19 pm by mav52 »
Tympani
Re: BDA-2 DAC
« Reply #636 on: 25 Oct 2014, 10:14 pm »
Whatever magic the "BDA-3" will surely offer, please-please-please include a polarity switch.
The sheer transparency of these units begs for this option, hopefully in the digital domain.
(its my only gripe with my BDP-2/BDA-2 combo)
mav52
Re: BDA-2 DAC
« Reply #637 on: 28 Oct 2014, 06:20 pm »
James I think it's time for a new BDA 3 thread :   http://audioshark.org/bryston-audio-40/bryston-bda-3-announced-6057.html#post100154
Since it appears to be available  Jan 2015, what will the price be ?
Re: BDA-2 DAC
« Reply #638 on: 28 Oct 2014, 06:22 pm »
$3195 list
alexone
Re: BDA-2 DAC
« Reply #639 on: 28 Oct 2014, 07:11 pm »
...a BDA-3?!? wow! :D
al.
