BDA-2 DAC and BDA-3 DAC
0 Members and 1 Guest are viewing this topic. Read 457201 times.
larevoj
Re: BDA-2 DAC
« Reply #220 on: 28 Feb 2013, 06:19 am »
To be or not to be.
Head down to the show room and spent close to 2 hours plugging in and out BDA-1/2 into the system running balance in/out with BDP-1 and BCD-1 as source. Also the first time listening to the Bryston Speakers!
Here are some brief summary on BDA-1/2:
1) One area the BDA-2 consistently noted in my notes is its smoothness in the highs. Its almost as if you have a little tube stage preamplifier though the entire setup were driven with only Bryston solid state electronics.
2) The pace and transient swings are still as snappy as before yet presented in an effortless manner and some may relate this to refinement
3) The centre stage took a step back deeper and the soundstage is a tad wider too giving you slightly bigger picture
4) Interestingly I had to turn up the BDA-2 about 1 notch to get about the same volume when comparing with the BDA-1. There could be a possibility where the BDA-2 were pushed down by about 1db to 2db but wasn't verified at time of audition.
5) There are tracks I can appreciate better on BDA-1 particularly with jazz vocals and some orchestra pieces where I like a little bite on the highs particular with string instruments and ambiance cues.
6) The smoothness of BDA-2 is pretty good especially in complex music arrangements allowing a little more separation in instruments.
7) The BDA-1 has an edge in energy and drive through its entire bandwidth and is more neutral in its interpretation
In terms of price there is a marginal increase on BDA-2 however which will suit you better really depends on your preference. Both sounds very alike but I can see where BDA-1 and BDA-2 strengths or weaknesses can draw out the best from your system when match properly. Its smart that Bryston kept the BDA-1 in their line giving folks the choice.
Cheers!  :thumb:
« Last Edit: 28 Feb 2013, 12:35 pm by larevoj »
Alpha10
Re: BDA-2 DAC
« Reply #221 on: 28 Feb 2013, 09:40 am »
Thank you for the review, very interesting.
One quick question, did you try turning the upsampling on and off with both units at all and the differences heard?
I much prefer upsampling off on my BDA1.
Cheers
larevoj
Re: BDA-2 DAC
« Reply #222 on: 28 Feb 2013, 11:02 am »
Hey...both up-sampling off...thats my preference too.  :thumb:
Cheers
Alpha10
Re: BDA-2 DAC
« Reply #223 on: 28 Feb 2013, 11:11 am »
Excellent, thank you.
 :thumb:
mav52
Re: BDA-2 DAC
« Reply #224 on: 5 Mar 2013, 05:44 pm »
James any NEW news on making this DAC DSD capable ?
  • The Demo is Everything!
    • http://www.bryston.com
Re: BDA-2 DAC
« Reply #225 on: 5 Mar 2013, 05:52 pm »
Still looking at it but nothing we are acting on any time soon. It appears USB out is the only legal way to do it.
james
mav52
Re: BDA-2 DAC
« Reply #226 on: 5 Mar 2013, 10:57 pm »
^  thanks James
gordon
Re: BDA-2 DAC
« Reply #227 on: 6 Mar 2013, 01:34 am »
Ditto - upsampling off is preferred (I'm using USB input from Mac Mini running Pure Music on top of iTunes). I do find that upsampling within Pure Music is an improvement.
Re: BDA-2 DAC
« Reply #228 on: 7 Mar 2013, 03:42 pm »
Dear friends,
I write just to let you know that we published (in English) review of your excellent DAC-2:
http://highfidelity.pl/@main-356&lang=en
I hope you'll enjoy it!
If you need any help, do not hesitate to contact me!
Best regards
Wojciech Pacula
High Fidelity/editor
6moons.com, enjoythemusic.com/journalist
ellsworth
Re: BDA-2 DAC
« Reply #229 on: 7 Mar 2013, 04:29 pm »
Hi James;
My security software (Webroot) doesn't like the link you just posted:
Re: BDA-2 DAC
« Reply #230 on: 7 Mar 2013, 04:36 pm »
Hi James;
Hi - all seems OK here???
james
ellsworth
Re: BDA-2 DAC
« Reply #231 on: 7 Mar 2013, 05:43 pm »
Thanks James. Sorry about the alarm. I'll sort it out at my end.
alexone
Re: BDA-2 DAC
« Reply #232 on: 7 Mar 2013, 07:33 pm »
James,
thanks for posting the review :thumb:.
does the BDA-1 also has two clocks for 44.1k and 48k signals like the BDA-2?
al.
Re: BDA-2 DAC
« Reply #233 on: 7 Mar 2013, 07:38 pm »
James,
al.
Hi Al
Yes it does.
james
alexone
Re: BDA-2 DAC
« Reply #234 on: 7 Mar 2013, 07:39 pm »
...and the BDA-2 has one big transformer instead of two smaller ones like the BDA-1. why?
al.
Re: BDA-2 DAC
« Reply #235 on: 7 Mar 2013, 07:45 pm »
al.
One transformer but its a Dual Core transformer with dedicated windings.  It is a custom made unit made for us.
james
Re: BDA-2 DAC
« Reply #236 on: 10 Mar 2013, 03:12 am »
Sent: Saturday, March 09, 2013 9:26 PM
To: James Tanner
Subject: Tin Pan Alley
HDTracks.com just put up new versions of Couldn't Stand the Weather and I'm listening to the 24/96 version of tin Pan Alley.
Sounds awesome coming from the BDP2! And you can print that!
David
Tattersall Sound Studio
Joker
Re: BDA-2 DAC
« Reply #237 on: 10 Mar 2013, 09:23 pm »
Am a happy owner of a BDP-1 and BDA-1 since a year. I am aware of the technical differences & capabilities between these and the "2s" meanwhile available for both of them. Does anybody have any views / reports on sonic differences between the "1s" and the "2s" in their respective combo? So would it be worthwile upgrading both components in your view? Thanks so much!
larevoj
Re: BDA-2 DAC
« Reply #238 on: 12 Mar 2013, 07:05 am »
Give A+ a try if you are running on SL. I find A+ is more transparent versus PM running through BDA on my system but if you are running on ML both Amarra and A+ is equally good depending on your preference.  :thumb:
Re: BDA-2 DAC
« Reply #239 on: 13 Mar 2013, 04:32 pm »
Hi Folks,
The Absolute Sound Magazine review on the Bryston BDA-2 DAC is out this week.  As soon as I get the PDF of the reprint I will send it to those wanting a copy.
Last line of the review:
"I cannot think of higher praise, nor can I imagine living without the Bryston BDA-2."
james
