BDP-2 Digital Player
0 Members and 2 Guests are viewing this topic. Read 652274 times.
unincognito
    • bryston.com
Re: BDP-2 Digital Player
« Reply #900 on: 1 Apr 2015, 04:55 am »
I am unable to persuade the BDP-2 to play DSD128.
Has anyone had success with this?
It was tested with a PS Audio DAC and BDA-3
Norton
« Reply #901 on: 1 Apr 2015, 06:49 pm »
Yes, no problem (over USB) to Chord Hugo.
Grit
  • - Garrett
« Reply #902 on: 18 Apr 2015, 11:46 pm »
Does the BDP-2 support gigabit ethernet or just 10/100Mbit?
I just transferred about 10 CDs (ripped to FLAC via dbPoweramp) from my Windows desktop computer to the OCZ Vector-4 solid state internal drive on my BDP-2, and then transferred the same files to my server (which has a regular Western Digital "red" HDD). Both the BDP-2 and server and desktop are all connected via Cat-6 cable, Netgear gigabit switches and a Netgear R7000 router, all supporting gigabit speeds.
The transfer speed to the BDP-2 was about 17MB/sec (megabytes). The transfer of the same files to the server was about 80MB/sec.
At the end of the day, I don't transfer files to the BDP-2 very often, so it's not problematic. But I was wondering if there's anything I can do to speed up the data transfer speed?
srb
« Reply #903 on: 19 Apr 2015, 03:09 am »
According to the BDP-2 Owner's Manual it states that it does have Gigabit Ethernet.
"The BDP-1 and BDP-2 include Ethernet network interfaces capable of 100 megabits per second (100 mbps) and 1 gigabit per second (1000 mbps) respectively. Real world network conditions make it unlikely that these maximum speeds will ever be realized, but only 3 megabytes (24 megabits) per second are required for high resolution music playback."
Your 80MB/s transfer rate seems like a reasonable real world gigabit speed, not sure why your BDP-2 is only just over a fifth of that.  :scratch: Must have something to do with the SSD and SATA interface.
Grit
  • - Garrett
« Reply #904 on: 19 Apr 2015, 06:51 am »
Yeah, the SSDs in both my desktop and the BDA-2 are capable of the 80MB/sec transfer rate. The even an older SATA bus would support that too. My best guess is the SATA driver in the BDA-2 isn't optimized for that (since that data rate isn't necessary for playing music). If not, I was hoping that perhaps a different brand of drive might fix it.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #905 on: 1 May 2015, 02:03 pm »
SUBJECT: Announcing Bryston Integrated Audio Device Card
May, 2015
Hi Folks,
We have been working on a Bryston proprietary “Integrated Audio Device” card with much improved specifications to replace the current two-piece ‘Soundcard’ and ‘SPDIF interface module’ (AES/BNC) utilized in our current BDP-2 Digital Player.
I am happy to report that an all new integrated version of the BDP-2 audio card is now going into production and should be available in a few weeks from now. All BDP-2’s currently on order will be fitted with the new Bryston integrated audio card.
Any current BDP-2 owners may have their units upgraded if desired.
Bryston
Norton
« Reply #906 on: 1 May 2015, 02:16 pm »
May, 2015
Hi Folks,
Bryston
That's interesting James.  I'm an existing owner in the UK.  What will the charge be for the upgrade and does it have to go back to a dealer or could you trust owners to fit?
David
« Reply #907 on: 1 May 2015, 02:41 pm »
David
A competent company like PMC could do the swap.  I am still pricing the parts but I would say around $500 US.
james
Rod_S
« Reply #908 on: 1 May 2015, 02:47 pm »
So does this affect the BDP-2's price? I plan on ordering mine mid-June and the dealer wants a 50% deposit.
Rod_S
« Reply #909 on: 1 May 2015, 02:48 pm »
So what are the better specs?
« Reply #910 on: 1 May 2015, 03:45 pm »
We are going to leave the price the same for now.
james
« Reply #911 on: 1 May 2015, 03:46 pm »
Below the threshold of our AP. Will put something together once we have production versions.
james
haxter1
« Reply #912 on: 1 May 2015, 04:55 pm »
Will the BDP-1 be upgradable or only the BDP-2.
Rod_S
« Reply #913 on: 1 May 2015, 05:25 pm »
james
Sounds good to me :)
« Reply #914 on: 1 May 2015, 05:35 pm »
Hi Haxter
Just the BDP-2.
james
Rod_S
« Reply #915 on: 1 May 2015, 05:41 pm »
james
What do you mean by "Below the threshold of our AP"?
« Reply #916 on: 1 May 2015, 05:49 pm »
We use very sophisticated analyzers and below threshold means it is below what the measuring gear can measure.
http://www.ap.com/products
Here's an example of what I mean from a reviewer measuring the BUC-1 - http://www.hometheaterhifi.com/dacs/dacs-reviews/bryston-buc-1-usb-converter/page-4-on-the-bench.html
james
Rod_S
« Reply #917 on: 1 May 2015, 05:53 pm »
Cool, thanks
vklyushnikov
« Reply #918 on: 1 May 2015, 06:58 pm »
Hi James,
How does a new audio card handles sample rate switching? Currently BDP-2 with BDA-2 fades about 500ms of track when sample rate changes on AES/EBU output. I had a long email conversation with Chris on this issue and he told me that this is shortcoming of SPDIF protocol. Are there any improvements in new device?
« Reply #919 on: 1 May 2015, 07:17 pm »
Hi James,
Hi
I can't say I have had that problem - the new one seems instantaneous.
james
