BDP-2 Digital Player
0 Members and 1 Guest are viewing this topic. Read 652308 times.
RonCH
Re: BDP-2 Digital Player
« Reply #880 on: 11 Mar 2015, 10:10 am »
What is the best way to integrate TIDAL playback into the BDP-2? I am thinking about subscribing.
It will be fully supported in summer.  Take a look at this thread: http://support.bryston.com/forum/viewtopic.php?f=44&t=198
lostsoul
« Reply #881 on: 11 Mar 2015, 10:43 am »
Thank you for the quick reply. I'll make sure I download the latest beta.
I did not realize the support forums started to work. Cool!
lycia
« Reply #882 on: 12 Mar 2015, 11:29 am »
I have connected up a suitable DAC to my BDP-2 but I find that the Audio Devices page in MM does not provide any facility for seeing the DAC or checking a box as described in the manual. However I can play DSD64 files to my DAC so obviously it is recognized.
I am unable to get the BDP-2 to play DSD128 or DSD256. Is this correct?
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #883 on: 12 Mar 2015, 11:54 am »
Hi
Which DSD DAC are you using?
james
lycia
« Reply #884 on: 12 Mar 2015, 12:09 pm »
I used my Meitner MA 1 DAC for DSD64 and borrowed an Oppo H1 for the higher numbers.
unincognito
    • bryston.com
« Reply #885 on: 12 Mar 2015, 12:14 pm »
You need to have S2.10 2015-03-02 installed and select MPD 0.18.21 to play dsd128
lycia
« Reply #886 on: 12 Mar 2015, 12:19 pm »
Thanks, Chris.
I will change the MPD setting.
Is DSD256 not available at this time?
unincognito
    • bryston.com
« Reply #887 on: 12 Mar 2015, 01:06 pm »
Dunno, don't have any to test
Phil A
« Reply #888 on: 12 Mar 2015, 02:11 pm »
Just sign up for the Just Listen Native DSD Newsletter and you get a sampler (download) including various formats - https://justlisten.nativedsd.com/albums/just-listen-1-compilation
And then you get a download free that changes once or twice per week - https://justlisten.nativedsd.com/
Samurai7595
Re: BDP-2 Digital Player - Failed Firmware Upgrade
« Reply #889 on: 13 Mar 2015, 09:04 pm »
My Bryston BDP-2 is still on firmware 1.60.  Last night, via my iPad Mini (Safari), I ran a Firmware Upgrade to upgrade it to 1.75 or 1.76 (cannot remember right now).  It took forever to run and in the end it failed.  What next?
« Reply #890 on: 13 Mar 2015, 10:43 pm »
Email Gary - he may be able to help - [email protected]
james
Samurai7595
« Reply #891 on: 13 Mar 2015, 11:06 pm »
james
Will do, thanks James!
R. Daneel
« Reply #892 on: 14 Mar 2015, 08:39 am »
Hi guys!
Do all of these discussions about DSD and MPD apply to BDP-1 as well?
Cheers!
Antun
MoPac
« Reply #893 on: 25 Mar 2015, 03:30 pm »
S2.06 2014-10-07   MPD 0.18.6
Hey Chris:
  Have not visited MM for a long time.  Use MPOD exclusivly for control.  Noticed the new version is
S2.10 2015-03-02 which is quite a jump from my above version.  Can I go straight to the new version or do I need interum versions installed first?
 The few times I did look at MM there was never an update message displayed.
  Thanks, Rich
unincognito
    • bryston.com
« Reply #894 on: 26 Mar 2015, 12:50 am »
Hey Chris:
  Thanks, Rich
S2.10 is was actually a complete redevelopment on a new Linux Kernel, so we went that long without any updates in-between. We have developed the firmware in such a way that you can jump any number of versions between updates.  Although in your case your just going from the second last stable to the most recent stable.
Cheers
unincognito
    • bryston.com
« Reply #895 on: 26 Mar 2015, 12:52 am »
Hi guys!
Cheers!
Antun
We have tested DSD64 on a BDP-1, not sure about DSD128.  We try to maintain the firmware in such a way that any features introduced aren't excluded from the BDP-1.
Cheers
Rod_S
« Reply #896 on: 26 Mar 2015, 11:16 am »
Do the BDP's ship with the latest firmware?
unincognito
    • bryston.com
« Reply #897 on: 26 Mar 2015, 06:58 pm »
Yes
Rod_S
« Reply #898 on: 26 Mar 2015, 08:00 pm »
lycia
« Reply #899 on: 1 Apr 2015, 03:56 am »
I am unable to persuade the BDP-2 to play DSD128.
Has anyone had success with this?
