BDP-2 Digital Player
ozzy
Re: BDP-2 Digital Player
« Reply #560 on: 26 Dec 2013, 03:53 pm »
James, Any idea if the music could be sorted by album in future updates?
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #561 on: 26 Dec 2013, 04:35 pm »
Hi
That would be a Chris question - so far I think only by Artist.
james
ozzy
« Reply #562 on: 27 Dec 2013, 11:44 pm »
Chris,
So how about it?
Will I be able to sort by albums?
unincognito
    • bryston.com
« Reply #563 on: 28 Dec 2013, 06:17 pm »
Chris,
So how about it?
The feature already exists,  the video below covers how to use the feature and other things.
http://www.youtube.com/watch?v=Ec8PMgXzd-A
Chris
unincognito
    • bryston.com
« Reply #564 on: 28 Dec 2013, 06:20 pm »
Is there any chance exasound e20 dac will work with bdp2 via USB?
Only if they ever release alsa compatible drivers
jhameeh
« Reply #565 on: 9 Jan 2014, 12:23 am »
What is error 05? How will I solve this?
unincognito
    • bryston.com
« Reply #566 on: 9 Jan 2014, 02:02 am »
Error 05 means the BDP has detected a power spoke in the line and is turning off its linear supply to protect it and the rest of the electronics.  Some power conditioners have been known to trip error 05 (over voltage) and error 04 (under voltage), so if the BDP is plugged into one try the BDP unplugged from the power conditioner.
Trying to catch under voltage or over voltage isn't possible with a multimeter due to the length of time they occur.  Essentially you would need an oscilloscope with an appropriate transformer to lower the voltage as to not fry your expensive oscilloscope.  Multimeters take a few reading every second and display an average, where an oscilloscope is taking millions if not billions of reading per second and displays each measurement taken usually in the form of a wave form.
Cheers
Chris
rompolompo
« Reply #567 on: 10 Jan 2014, 07:30 pm »
As long as they use USB Audio Class 2.0 specs you will not need dedicated drivers.
unincognito
    • bryston.com
« Reply #568 on: 10 Jan 2014, 09:17 pm »
The e20 dac is proprietary
Cheers
Chris
rompolompo
« Reply #569 on: 13 Jan 2014, 01:04 am »
Indeed.
R. Daneel
« Reply #570 on: 16 Jan 2014, 06:45 pm »
Are there options for color of the display on BDP-2 like on SP3?
drummermitchell
« Reply #571 on: 16 Jan 2014, 06:54 pm »
Blue and green I believe.
I have the blu led's on the BDP-2+BDA-2 and mah 28's
For me the blu against the black face plate visually takes them to another level for eye appeal.
R. Daneel
« Reply #572 on: 16 Jan 2014, 07:13 pm »
Cool! So the BDP-2 has a lit power button like the BDA-2?
drummermitchell
« Reply #573 on: 17 Jan 2014, 02:48 am »
Yes both have the led right above the button,my flash on the camera is to hot for a good close up,
the flash thins out the blue  somewhat but gives you an idea.
But even this so/so shot the blu led's look 1000%better than the green against the black :thumb:.
jhameeh
« Reply #574 on: 17 Jan 2014, 03:53 am »
Mine is all green  :thumb:
R. Daneel
« Reply #575 on: 17 Jan 2014, 03:39 pm »
Beautiful!! Thank you fellas!!
My BHA-1 and BDA-2 have green LEDs but I might just have the BDP in blue! Mine have silver front panels, though.
Cheers!
Antun
R. Daneel
« Reply #576 on: 19 Jan 2014, 12:35 pm »
Hello!
I read in the opening post that BDP-2 will be ready for USB 3.0. Has this feature been implemented?
Also, I read on many occassions that BDP-2 is much faster than BDP-1 when loading times are in question. Can anyone give me an example? For instance, once the BDP-2 is powered on, how long does it take for it load your hard drive / USB key and how large is your drive?
Cheers!
Antun
« Reply #577 on: 19 Jan 2014, 01:23 pm »
Hello!
Cheers!
Antun
Hi Antun
We have not incorporated USB 3 yet as we find it is really not necessary as USB 2 is 10 times faster than what is required to playback high resolution music files.
james
R. Daneel
« Reply #578 on: 19 Jan 2014, 03:51 pm »
Hi Antun
james
Thank you James!
Cheers!
Antun
unincognito
    • bryston.com
« Reply #579 on: 19 Jan 2014, 03:53 pm »
Hello!
Cheers!
Antun
Hi Antun,
The microprocessor is 2-3 times faster in the BDP-2 then the BDP-1, to say whether or not this advantageous to your hardware configuration I can not say.  This increase in performance isn't seen everywhere, if something is already a "walk in the park" for the BDP-1 in the first place then the BDP-2 isn't likely to be any faster.  For example, reading the contents of a drive that is formatted as Fat32 isn't very CPU intensive in comparison to reading files off of a drive formatted as NTFS.  So where a BDP-1 might take 20 minutes to read the contents of an fat32 formatted drive, the BDP-2 will take an identical amount of time.  However if that drive is not fat32, but rather NTFS then the BDP-2 will take nearly half the time to read in the contents as the NTFS module is very CPU intense and will max out the resource.
Chris
