BDP-2 Digital Player
0 Members and 2 Guests are viewing this topic. Read 653707 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: BDP-2 Digital Player
« Reply #1460 on: 17 May 2016, 06:24 pm »
Great set-up - ENJOY :thumb:
james
John-7
« Reply #1461 on: 18 May 2016, 04:06 pm »
Hello.
I noticed a price increase on the BHA. Is there a price increase on the BDP-2 ? What's the Canadian MSRP ? thanks.
« Reply #1462 on: 18 May 2016, 04:10 pm »
Hello.
BDP-2 is $3295 currently.
james
John-7
« Reply #1463 on: 18 May 2016, 05:05 pm »
Thank you James. I assume 17" black with blue lights to match my BHA is possible ?
If so, does the blue change the LEDs but leave the display green? Looks green from the images.
Thanks.
« Reply #1464 on: 18 May 2016, 05:16 pm »
Thanks.
Hi
The display and the LEDs are blue but the LEDs are a deeper blue colour.
james
John-7
« Reply #1465 on: 18 May 2016, 05:28 pm »
Thanks again.
Yitshak
« Reply #1466 on: 18 May 2016, 06:09 pm »
james
Thanks James
Tympani
« Reply #1467 on: 19 May 2016, 12:59 pm »
Hi
james
It seems there's been a change in the blue displays compared to my BDP-2 from 2 years ago. The glass overlying the display on the older units had a green tint, giving the display an "aqua" tint, whereas current blue displays appear a true blue. Is this correct, James? Current setup looks better integrated with the LEDs, IMO.
« Reply #1468 on: 19 May 2016, 01:03 pm »
No I think it is the same lens its just shows up a little different in photos depending on lighting.
james
XMAN
« Reply #1469 on: 20 May 2016, 02:46 am »
Hi James, I just received my bdp2 and love it just having difficulty playing dsd one I have comes out as 352.8 and the hd X 2 test file doesn't play at all.  The file doesn't display on my iPad but I can see on the player display any ideas?
unincognito
    • bryston.com
« Reply #1470 on: 20 May 2016, 03:34 am »
Make sure the BDA-3 is enabled as a DSD capable DAC in the Audio Devices settings page and you should switch the version of MPD from 0.17 to 0.19 (require a reboot before it takes effect).
http://www.bryston.com/PDF/Manuals/BDP-2_MM_Manual.pdf
davidtgoh
« Reply #1471 on: 20 May 2016, 04:47 pm »
James,
Is there any chance that the BDP-2 could read and self-extract SACD and Blu-ray iso files in the future (not sure how JRiver does this)?
David
PS-still getting "pops" with DSD rips.
XMAN
« Reply #1472 on: 20 May 2016, 07:33 pm »
I tried the update it load but only .176 not .19 also can play dsd X 1 but not x2 after I adjusted settings.  The x2 file still a no show in mm but shows on the player display just won't play
unincognito
    • bryston.com
« Reply #1473 on: 20 May 2016, 08:39 pm »
you need to reboot after saving the change
XMAN
« Reply #1474 on: 21 May 2016, 12:52 am »
All good now thanks for your help
XMAN
« Reply #1475 on: 21 May 2016, 04:24 am »
Gremlin is back mm has dropped the dsd x2 file again it was there played it now it's gone again.   Able to play directly from bdp but not mm
Update: I had to select the bdp in the settings and that seems to work now
davidtgoh
« Reply #1476 on: 25 May 2016, 04:59 pm »
Backup system.  I have a BDP-2 with 1TB internal and two 4TB usb drives.  I'm looking for ways to automatically back up all three drives, and also have the physical hard drive back up to a cloud based backup (Backblaze). Anyone had experience with backup up multiple drives perhaps via NAS?
wilsonij
  • BDP1>SP3>7B3s> Vandersteen Quatros
« Reply #1477 on: 25 May 2016, 08:17 pm »
If you have access to a computer which can "see" all of the storage devices on your network, then I've found FreeFileSync - http://www.freefilesync.org - to be superb and keeps the three copies of my entire music collection (two on local drives and one on a NAS) all nicely synchronised :-)
Ian
Marius
« Reply #1478 on: 25 May 2016, 08:32 pm »
Carbon copy Cloner works hassle free and most secure. Highly recommended albeit non free:https://bombich.com/
Simple mode and highly adjustable and automated if needed/wanted.
Cheers Marius
Ps
If you're on a Synology, cloud sync works great with various other cloud services . Careful with Cloudserver though, it eats your drives....
Marius
« Reply #1479 on: 25 May 2016, 08:38 pm »
Ian
Thanks! Never heard of this, my loss apparently . Looks very promising. Great find.
Cheers Marius
